Picked up a 67 a few months back. While doing some work in the dash, I've somehow managed to lose my turn signals. They were working fine when I got the van and now I've got nothing. All fuses look good, but there is some wiring problems from previous owner, but like I said the turn signals were working. Not sure if I've jarred something loose or what? Been working on it for a few days now and still can't figure it out.
Lost turn signals
Re: Lost turn signals
,,,,does it have a separate switch for the 4 way flashers and do they work?
cole63- Number of posts : 90
No the flashers don't work. Didn't see a flasher under the dash, but like I said the turn signals were working before.
work that 4 way switch a couple of times to see if the turn signals come on,,,,,,you surely have to have a flasher,,,,,,,I would say both flashers are clipped to the back of the speedometer,,,,,I think the fuse is on top of the headlight switch,,,,,did you test it to be sure its good or not making a good contact?
Ok ill try the switch some more. I did replace one fuse that was blown and was covered in aluminum foil. Like I said they were working and now nothing. I'm sure it's something simple just haven't figured it out yet.
Fixed the turn signals today. Previous owner had put in an aftermarket flasher that didn't have power going to one post of the flasher. Thanks for the help Donivan65
