+11
equium
SIN BIN
15 posters
    THE A100 SWAY BAR END LINK SOLUTION! Now with pic!
    SIN BIN
    SIN BIN
    Number of posts : 68
    Registration date : 2010-07-05
    THE A100 SWAY BAR END LINK SOLUTION!  Now with pic! Empty THE A100 SWAY BAR END LINK SOLUTION! Now with pic!
    Post by SIN BIN Tue Sep 07, 2010 9:55 pm
    OK so now it is finally time for me to give back (to all the A100 drivers at least) for all the help everyone has given me thusfar.
    So here is the skinny...(drum roll please)
    The end links fit PERFECT! They bolted right on, no problems Cool
    They are for a
    1980-1996 F250
    or
    1980-1986 F350
    Part #NCP 2652071
    THE A100 SWAY BAR END LINK SOLUTION!  Now with pic! IMG_1119
    Hope this helps out someone else. Very Happy
    Number of posts : 3046
    THE A100 SWAY BAR END LINK SOLUTION!  Now with pic! Empty Re: THE A100 SWAY BAR END LINK SOLUTION! Now with pic!
    Post by RodStRace Wed Sep 08, 2010 6:49 am
    Thanks!
    Number of posts : 1319
    Post by 67a 100 pickup Wed Sep 08, 2010 4:08 pm
    Added to the parts list!!! Thanks....
    Number of posts : 2198
    Post by EconoUSAparts Wed Sep 08, 2010 7:05 pm
    Great find. Are they the same length as the stock ones? The stock ones work on Econolines too.
    Number of posts : 12248
    Post by donivan65 Wed Sep 08, 2010 11:13 pm
    THE A100 SWAY BAR END LINK SOLUTION!  Now with pic! Ford_s10
    Number of posts : 922
    Post by wylee Thu Sep 09, 2010 3:59 am
    thanks for the info.....................
    SIN BIN
    SIN BIN
    Post by SIN BIN Thu Sep 09, 2010 11:06 am
    More than glad to help cheers
    Post by EconoUSAparts Thu Sep 09, 2010 7:29 pm
    donivan65 wrote:THE A100 SWAY BAR END LINK SOLUTION!  Now with pic! Ford_s10
    Wow at almost a c-note a set it may not be such a great deal after all scratch
    Post by donivan65 Thu Sep 09, 2010 7:48 pm
    Maybe the repair kit would work,,,,,,,,,
    THE A100 SWAY BAR END LINK SOLUTION!  Now with pic! A100_s10
    SIN BIN
    SIN BIN
    Post by SIN BIN Fri Sep 10, 2010 10:51 am
    donivan65 wrote:Maybe the repair kit would work,,,,,,,,,
    I was going to go that route, but I had to have a backup plan if they broke while removing them.
    Personally, I think $100 to fix a problem that shows up every 20 years is pretty reasonable. Wink
    Post by donivan65 Fri Sep 10, 2010 11:25 am
    The main point is you found a solution to a problem,,,,, the sway bar link off a 96 Ford pick up fits a 66 Dodge Van,,,,,,and choices on where to get them,,,,,brand new,,,,,as a repair kit or from the wrecking yard,,,,,,thats all that matters,,,,,,,
    SIN BIN
    SIN BIN
    Post by SIN BIN Fri Sep 10, 2010 12:34 pm
    donivan65 wrote:The main point is you found a solution to a problem,,,,, the sway bar link off a 96 Ford pick up fits a 66 Dodge Van,,,,,,and choices on where to get them,,,,,brand new,,,,,as a repair kit or from the wrecking yard,,,,,,thats all that matters,,,,,,,
    I couldn't agree more bounce
    Post by donivan65 Sat Sep 11, 2010 12:55 pm
    Do you have a part number for that Napa 97 Explorer front sway bar replacement link? The one it shows does not look like what we need,,,,,,,,
    Number of posts : 8770
    Post by dix Sat Sep 11, 2010 6:34 pm
    WOW I AM SORRY MY SON HAS A 97 EXPLORER THE END LINK I USED WAS 1980 TO 1996 FORD F150 PICKUP REAR. THE PRICEON THIS LINK IS NOT CORRECT THAT IS WHAT I PAID FOR 2http://www.napaonline.com/Search/Detail.aspx?A=MRC18276_0131681599&An=599001+101996+50028+2028020
    Post by dix Sat Sep 11, 2010 6:37 pm
    IF THE LINK DID NOT COME UP TRY NAPA #MRC18276
    Post by dix Sat Sep 11, 2010 6:43 pm
    ALSO TRY NAPA # MRC18275 THIS ONE IS STRAITE BUT WOULD STILL NEED CUT AND WELDEDhttp://www.napaonline.com/Search/Detail.aspx?A=MRC18275_0279995569&An=599001+101996+50028+2028020
    Post by donivan65 Sat Sep 11, 2010 10:06 pm
    Now I see it,,,,,,f150 for the rear,,,,,,,a better choice for someone who has lifted their van or pick up,,,,,,,so keep the info coming,,,,,,,someday, somewhere, someone will need this information,,,,,,,,,it's all about choices,,,,,,we put them out there,,,,,,,pick the one that suits your needs,,,,,,,,,,
    THE A100 SWAY BAR END LINK SOLUTION!  Now with pic! Dodge_10
    Number of posts : 759
    Post by kiwimopar Tue Apr 19, 2011 2:16 am
    Where did the sway bar itself come from? Do you guys have a part number or model number? Question
    Post by RodStRace Tue Apr 19, 2011 7:34 am
    It's a stock one for the vans. Some have it, some don't.
    It bolts to the rails and extends through the sides of the belly pan.
    Number of posts : 957
    Post by slowflapper Tue Apr 19, 2011 1:51 pm
    RodStRace wrote:It's a stock one for the vans. Some have it, some don't.
    you mean they dont all drive like ski boats?
    Post by kiwimopar Tue Apr 19, 2011 3:47 pm
    Awesome Shocked
    Anyone got a spare sway bar for sale? Wink
    Post by EconoUSAparts Tue Apr 19, 2011 7:35 pm
    Since the A100 link fits the Econoline I would assume the Econoline link fits A100. Kanter has them if you call but their website doesnt show it. Price is about $20 so Im told.
    Post by 67a 100 pickup Wed Apr 20, 2011 3:47 pm
    kiwi... sent you a pm about my spare.
    Post by kiwimopar Wed Apr 20, 2011 5:21 pm
    67a 100 pickup wrote:kiwi... sent you a pm about my spare.
    Cheers, reply sent Cool
    equium
    equium
    Number of posts : 107
    Registration date : 2011-04-25
    Post by equium Mon May 27, 2013 9:47 am
    I wanted to share my progress so others dont make my mistake. I wanted to save $$ so I thought i'd keep my links, and use the repair kit as mentioned by donivan65. The Oreilly part number referenced over to a Moog K8434, which I bought from Autozone. When I placed the bushings into the large circle of the link, the bushings wiggled as they were too small. This is when it hit me that these bushings are for a link that would have gone on a ford. so it looks like i'm back to square one and i'll have to get the entire set-up, links and all.
      Current date/time is Tue Nov 26, 2024 1:10 pm
