Hi Art,
Yeah the narrowing of the seat started out as, "Okay, I'll just narrow
it and re-upholster..." Then I had to narrow everthing including the
aluminum space frame (just learning TIG/GTAW right now) plus I
had to narrow the two torsion bars that make the seat back return
from reclined to upright- ha! Overall, it was fun, just a lot of figurin'
to keep it seamless.
I could have gone with Fiero seats, but thought I'd be "different" and
found a great deal on 2010 Caravan 2nd row seats that fold forward
flat and recline back pretty good. They are real thin in the butt area
which was good to get the seating low once I fabbed the brackets.
Oh yeah, the seats had arm rests along both sides. I canceled the
outboard ones and will place the Door Armrests to match. The Caravan
armrests actually twist INWARD into the seat back when they are
folded up- something really nice to get out of the way of opening the
Doghouse.
Hi Duane,
I hear ya, good fitment of the belts is of primary importance. I'm 5'10"
and the upper mount does me right even when reclined a bit. I road
tested it (checking the inertia lock) and things felt real good (and QUIET!)
The modern seats are much quieter than the stock sprung seats.
I think if I had a 3-window I would go the route you did as it is so simple
and has more choice for making a good hardmount (I had to weld into
the outer skin from the inside which would cook a good paint job.)
Here are some pics of the brackets I did:
I used .063 wall 1x1 square tube.
My seat bracket (black) actually rides UNDER the outer bracket (silver) which
gets the seat pretty low. In fact if you look closely I had to cut down the
battery box 1-1/8" lower!
I even had to chop the Inner Bracket 1-1/8"
The weld can just be seen on the left post, mid way, but I dressed the weld
then painted it.
I used 4 bolts to attach the two brackets as the outer backet holds the
black seat bracket/adapter in suspension,
Oops! Just looked at what I wrote, sorry for the hijack Art!!!
George
