    Painting your Carburetor
    Number of posts : 2067
    Painting your Carburetor Empty Painting your Carburetor
    Post by sasktrini Thu Aug 12, 2010 7:08 am
    In my neck of the woods, retailers don't sell the carburetor refinishing kits such as that by Eastwood. I'm looking for an alternative method that will restore the look of my carbs while withstanding exposure to fuel without flaking off and such.
    Duplicolor sells Zinc Chromate primer that I thought would promote adhesion. Then their engine enamel should withstand the chemicals...
    Any thoughts? What have you done to refinish a carburetor? Were you successful?
    Number of posts : 3046
    Painting your Carburetor Empty Re: Painting your Carburetor
    Post by RodStRace Thu Aug 12, 2010 10:45 am
    I have tried different chromate paints (transmission case) and wasn't pleased with the results.
    I've also seen rebuilt carbs painted Silver (no undercoat) and while it held up okay for a short time (6-12 months), the typical gasket seepage would discolor it and it would rinse off with carb cleaner.
    If you do decide to paint a carb, make SURE to mask off interior areas so the paint doesn't come loose and plug the passages.
    Holley does offer a carb restoration service that reapplies metal finishes, but it is fairly expensive. Plating is not something a DIY'er can do easily except the dark finishes for hardware or bluing typically used on firearms.
    Post by sasktrini Thu Aug 12, 2010 10:49 am
    Totally, Rod!
    What I read about the zinc chromate primer is that it's like etching primer for aluminum... that's why I thought it may work. I'd like to figure something out so I can buy what I need this evening and reassemble my carb before the weekend is out... that means painting tonight I guess.
    Keep the advice coming... thanks for any and all opinions.
    Post by sasktrini Tue Aug 17, 2010 7:57 am
    The Universal Gold Engine Enamel from Duplicolor is pretty shiny for a carb. Oh well, it's done. Actually already did the fuel test... when I tested it last night, there were a couple leaks that I have to tend to. Will all the paint flake off in a couple weeks? Maybe. Oh well, at least I tried. And yet, maybe it will stay nice.
    Painting your Carburetor IMG_0501
    Hopefully, there is a happy ending to come in this story!
    Post by Guest Thu Sep 02, 2010 6:57 pm
    I used gold colored wheel paint on my carb about 2 years ago. I found that out from watching Stacy David on Gearz rebuild some carbs. Still holding up except for the screws have some paint chipped off from taking the carb apart to fix the float.
    Post by sasktrini Thu Sep 02, 2010 10:40 pm
    Well, I painted this carb and the Holley 1904. This one didn't work, and I ended up buying a reman'd carb. Because of all the issues with fuel, it did flake, never really got hot on the engine to cure the paint. However, the Holley worked okay on the engine and looks great still. Hopefully when it gets put into permanent service, it will be good.
    I will have to look up some Gearz archives to see if I can find it...
    Last edited by sasktrini on Thu Sep 02, 2010 10:42 pm; edited 1 time in total (Reason for editing : Gearz)
    Painting your Carburetor Empty carb paint
    Post by Twinpilot001 Sun Oct 03, 2010 5:30 pm
    eastwood sells a carb paint-or-?? have the parts plated- not chrome -like a zinc dip?/ eastwood i think also sells thart stuff
    Post by Nightmoves Sun Oct 03, 2010 6:44 pm
    Aren't they just anodized anyway? Kinda what it looks like.
    Number of posts : 355
    Registration date : 2010-05-30
    Post by toad Mon Oct 18, 2010 11:30 pm
    I painted my Gremlin carb silver, let it set up, then sprayed it with oven cleaner. It dulled the silver to a gray and is holding up to this day. That was over ten years ago. I don't know why this worked, or why I did it at the time, but it still looks good.
    Post by Twinpilot001 Fri Dec 09, 2011 4:19 pm
    look on youtube for zinc plating. it can be colores too. There are some guys there that are doing it very cheaply too -Check it out!
      Current date/time is Sun Nov 17, 2024 10:57 am
