A man with a big truck?
and...
Is it a pony?
Shadowfax
Looks like it was a good horse, that got rode hard and put away wet.
But it's still a good horse.
The body is just what ya see here.
Nothing major, except two smallholes cut in the roof for vents.
Keystone Mags and good radials.
I don't see any rust-thru anywhere.
It's got a factory automatic (pretty sure it's a powerglide, since it has the cast webbing grid on top of the housing), with the proper tail-shaft housing/trans mount hanger, the shifter has the PNRD21 needle indicator, but the clear plastic with the actual letters is gone.
The wind wings have been removed, but only plexiglass replaces the driver and pax windows.
The door handles have been shaved, without thought for how to get in and out since nothing but inner door handles remain.
The only real bondo I find is on one corner rocker, under the fuel filler
The door jambs on front aren't rusted out.
The spring hangers aren't bent or rusted out.
Dual exhaust for that full fart sound from the 6-banger...
The grill is straight as an arrow, the bumpers are gonna get removed, and the frame horn holes filled for the 'roll pan' look front and rear.
The pan shroud has a hole cut in it... o.0
and the best part?
that it already has a bed in back?
NO!
Blown Out Glasspacks!
woohoo!
