I understand that people have pulled the sixes up and out through the side doors... but I'm not sure that this would be possible with a V8 motor. At the very least the headers would have to be removed, which could be very difficult if not impossible if the header bolts/nuts are frozen. Then I'm not sure the heads will clear the lid opening anyway.
The other method, I understand, is to raise the vehicle high enough to drop the motor from below. A couple of concerns spring to mind: how high? Since the front axle would be in the way, it would have to be removed to drop the motor. Then the question of how do you support the front of the vehicle with the front wheels removed?
MOst of the lift's I've seen (at the local community college) don't have lift arms long enough to connect to the lifting points for this van - which are basically at the axles. With the front axle removed, the next place to lift the van at the front would be the "frame" supports just inside the front bumper. I've used jack stands there in the past (really big semi truck size jack stands, at that). I could see maybe a drive-on lift, then jacking up each wheel and using the semi size jack stands to rupport the front, remove the front wheels/axle, then dropping the motor providing there is space on the drive on lift for dropping a motor.
Ideally a two-column lift would have arms long enough to connect to all four corners of the van, but I'm not sure these exist - or if they do, they are at big garages that normally handle things like city buses or RV's.
Well, long winded, I guess, but has anyone ever pulled a V8 motor out of an early Chevy van? Short of chopping off the dog house at the van floor, how did you do it?
