where is the fuse box. i cant believe they they would build somthing without a fusebox
wheres the fuse box ?
delraydoug- Number of posts : 210
lectricman- Number of posts : 339
Re: wheres the fuse box ?
ford econoline should be attached to the headlight switch... it is made as the plug for it.... silly, I know, but true....
to get the headlight switch out you need to grope around and find the button on the switch body. then you can pull the shaft out. undo the screwed in collet and the switch body will fall down. carefully move the thing out from behind the dash so that all the old wires dont get buggered up. the fuse box is piggybacked onto the switch body. its retarded.
Sy Hollinshead- Number of posts : 466
When i ripped out the old wiring in mine, i was looking everywhere for the fusebox, and couldn't believe what somebody actually designed for that van.
how many fuses are there ? thats a odd place. Would have never even thougt of looking thier. sounds like it would be hard to change a fuse or even check like if your wipers stoped working or somthing
I think mine has 5 spaces and only 4 being used?? this is only by memory on my first econo though... I haven't gotten that far with this one yet.... lol
it would be nice to wire in a different fuse box from the wreckers out of a little car. put it somewhere better
I have just finished doing exactly that today. It makes life so much easier in the long run, and now i know there will be no fires. I had a fire in my 1970 Mustang fastback a couple of years ago. It wasn't much fun when the interior filled with black smoke in about half a second....!!! The passengers in the back were petrified, as they couldn't get out until we got out, and i was trying to beat out the flames with my hand...!!
Anyway, have a look at my thread in the projects section, you can see where i put my fuseboard....
Sy
Sy
rev.chuck- Number of posts : 71
Registration date : 2010-03-08
autozone sells a fuse holder deal i have one in my van for the radio fuse.. also i find it easier to remove the inst cluster to get to all that wiring
