    Steering Stabilizer?
    Number of posts : 387
    Steering Stabilizer? Empty Steering Stabilizer?
    Post by whopman Thu Jul 15, 2010 3:08 am
    Anyone using a steering stabilizer on their front end? I removed a well worn out one ( don't know why it was still there) I found one online from MOOG for $60. And says it is for 64-66 Chevy G-10 vans. Any pro's or con's to using one?
    scratch
    Number of posts : 946
    Steering Stabilizer? Empty Re: Steering Stabilizer?
    Post by BvrWally Thu Jul 15, 2010 5:49 am
    Here is a shot of the one I have had on mine for several years with no problems!
    Steering Stabilizer? WheelsStraight
    B.W.
    Post by whopman Thu Jul 15, 2010 6:39 pm
    thanks BW gonna order it tomorrow
    ChevyVanMan1
    Number of posts : 425
    Post by ChevyVanMan1 Fri Jul 16, 2010 7:09 am
    Seems like that would lessen the play a little bit in old, worn out steering boxes. Of course the play would be the same it just wouldn't feel the same. If anybody has used the Moog part stated above (or any other available assembly), I'd love to know the part number and their experience--especially if it adds any considerable effort to turning the wheel (I have to park in tight places). Thanks!
    Post by whopman Fri Jul 16, 2010 8:48 am
    Steering Stabilizer? Ssd99_10
    this is the moog part. do an online search and you can find it for around 65 bucks. the moog part # ssd99
    Post by BvrWally Fri Jul 16, 2010 9:58 am
    I personally never noticed any difference, just got rid of any shimmy when you hit bad roads! I have used it for a long time and it has held up nice.
    B.W.
    Post by donivan65 Fri Jul 16, 2010 10:33 am
    It sure makes my van hard to park,,,,,,,its just a shock absorber,,,,,,the faster you turn the steering wheel, the harder it becomes,,,,,but its been on there a long time,,,,,,and I got wide tires, offset Mags and disk rotors on it so those are the worst conditions for easy steering anyways,,,,,,,,but it does help the handling, especially in wind, when you are going down the road.
    back2thewoods
    back2thewoods
    Number of posts : 842
    Post by back2thewoods Sun Jul 18, 2010 2:22 pm
    i actually found one in j-c whitney, seems to help some
    Post by whopman Sun Jul 18, 2010 4:30 pm
    I ordered it today from O'reilys auto..they matched the internet price I found of $60...should have it Tuesday morning. Will install and see! Thanks to all for the input!
    Post by whopman Fri Jul 23, 2010 2:13 pm
    After completing the disc brake install I need the front end aligned. Got that done this morning. The shop is awesome...they do things the old school way...speed balance the tires on the car! Hard to find anyone who does that anymore....so they started the alignment and got the toe in set correctly but camber was out of wack...had to tweek the axle to set.....turned out great...steering wheel almost lined up so pulled the steering wheel and centered it. Installed the steering stabilizer.It does add some(very little) effort to the steering but it absorbs almost all the play out of the worn gear box...definitely makes it more pleasurable to drive.
    Steering Stabilizer? Steeri10
    Post by BvrWally Fri Jul 23, 2010 9:14 pm
    Yes they are worth their weight in gold at times! IMHO
    B.W.
    Post by donivan65 Fri Jul 23, 2010 10:22 pm
    So how did they fix the camber?
    Post by whopman Sat Jul 24, 2010 3:43 am
    D65 they have a set of rams and chains on their alignment lift... they wrap they chains around the axle and then use the hydraulic rams to push the axle up with the chains holding the axle and actually bend the axle slightly to gain the camber needed..it is not much ...the reason these old axles need adjusting is caused by the PO's that would jack the van up using the center of the front front axle creating a bowed axle...the alignment is simply reversing that abuse and bringing it back to specs. I only jack the front end up being as close the the leaf perch as possible.
    Post by donivan65 Sat Jul 24, 2010 9:17 am
    So you had too much Positive Camber?
    Post by whopman Sat Jul 24, 2010 11:49 am
    D65 yes more on driver side then pass. side....he said he could adjust positive or negative....but like I said a lot of folks think its ok to jack the front end up from the center of the axle..when doing this it slowly arcs the axle up in the center causing positive camber....Don't know if it all occurs at once or over a period of years...but it seems to happen...
    Post by donivan65 Sat Jul 24, 2010 10:06 pm
    The front axle sure does not get much attention,,,,like on my van, the front tires started wearing out on the insides, but there was like over 300,000 miles on that axle. The Camber was way negative,,,the tops of the tires tilted in,,,,from old age,,,overloading the vehicle, hitting a curb or speed bump too fast,,,,,so you do need more than just the toe in checked,,,,,,,,,
      Current date/time is Tue May 28, 2024 3:53 pm
