Lazarusvan wrote:Dumbass alert: It helps when the switch is turned "on." I wondered why it had gotten warm last time and all the sudden stopped working... Our weather was briefly cold and then got warm (sorry snowbirds). We'll be back up to 65 degrees this Friday.
At least I can admit my shortcomings...
Just to update myself, I was wrong as the it wasn't switched off as I had thought. It was all the way over to the right in the "On" position. It just blows some warm air. No way it is "toasty" as DIgz mentioned. A couple of questions:
1)What temp should this put out if I test with IR sensor?
2)Should my Taurus radiator fan have any bearing on the way this puts out heat? I had my wife check from the passenger seat and unless she is mistaken, it immediately started blowing warm (from cold) on one occassion when I flipped the fan off from low speed. We tried it again later and nothing changed as it was warm already. Again, engine temps were running around 190-195 and temp outside was in the 40's.
3)The middle position "Air" will blow just as much the right position "On" at times. Is the "air" position just a low vs. "on" for high? My fan blower does appear to work.
If all this sounds like a bad core, that's understood. Just making sure and want to learn before I change it out.
