Window Louvers
63chevyvan?- Number of posts : 125
Window Louvers
Re: Window Louvers
Great Deal!!!!
DanTheVanMan- Commissioner
- Number of posts : 7900
Re: Window Louvers
Re: Window Louvers
Dan, what did you stick them on with?
63
63
Re: Window Louvers
some fit under the rubber gasket and some use 2 sided tape
Re: Window Louvers
63chevyvan? wrote:Dan, what did you stick them on with?
63
Chris is right. In the pic their just sitting there but when I took the rear windows out I trimmed the edges to be a 1/4" smaller than the window glass so when I put the new seals in I will install them with the glass so they won't ever just fall off.
Dan
Re: Window Louvers
Sounds good. The passenger side gasket on the van looks to have been installed backwards, so I've got to change them out any way.
Thanks, 63
Thanks, 63
Re: Window Louvers
NP>>>>
