Ok so I got a used HEI for the 64, and got the wires this morning , so idecided today was a good day to get it in.I checked before removing my old points dist., and rotor was pointing towards #1 cylinder, and was timed and running great before removing.As far a i could find in archives Don stated to check rotor position and put the HEI rotor same way, well the HEI wouldnt go all the way down(on the block where the dist. sits flush) with the rotor pointed towards the #1, as did the original dist..The small slot at the end of dist. shaft would only slide in(down to seat on block) with the rotor facing more towards the left(#6 cyl. maybe)see pic of how it is setup.
[img][/img][img][/img]
I went ahead to see if it would start with the way it is in the picture above , with the wires placed according to what I know(not much), #1 where rotor pointed, and then in clockwise firing order from there(1,5,3,6,2,4), and it works, well after I plugged in the wires into the HEI cap.I adjusted by ear and sounds fine and runs fine, but i really cant tell difference. The timing light I have, which is an old Grand/Auto parts store, doesnt work with this setup, but does work with my old points setup, do I need a newer timing light?Probably should anyway, but seems weird that it didnt work.
Ok anyway, do I have my HEI setup correctly, like I said it starts fine, and runs too, but is not setup like the other HEI's i have seen that Don has posted, almost similar placement of cap, but wires are more setup like the old points setup, with the #1 wire closest to the #1 cylinder and the rotor pointed that way as well.I tried moving the rotor, and had to crank over the engine to get the dist to drop in and rotor to point to #1, and then re did all the wires as well, but wouldnt start, so I went back to the way I 1st installed it and it runs and drives , what in the world am I doing wrong here, or am I???Help please all you master mechanics!!!!
