Hello, I have a '66 Econoline Falcon, 240 with a C-4 behind it. Just bought the van in Portland, some of you may have seen it before when it was referred to as "Phils Phalcon". Im having the typical heat soak problem and I cant find a spacer anywhere to remedy! Running a 1BBL Holley currently. Im looking for a Phenolic spacer, or just something that will work? I have been lurkin here for quite some time, and checkin out the place! what have you guys tried to remedy this?
New guy with question
Re: New guy with question
I can't help you , but like to Welcome you to the site
DeeBee- Number of posts : 7
Registration date : 2010-04-17
Thanks G-man!
Welcome some of the guys install cool down fans I have not tryed that yet but mine always starts just a little harder to get fired up after sitting for awhile.Im running a 289 with a edelbrock 4bbl right now rebuilding a 1850 holley with a 2 inch spacer im going to try soon
I have an electric fan that comes on with a thermostat. Its not too bad starting, just have to run it for a minute to clear it. Im not running a traditional fan on the front of the engine, thought about installing one. I will probably build some sort of cool air tube into the doghouse so the engine is sucking cooler air. Its not overheating though, the carb just gets too hot due to sitting right over the exhaust manifold. Runs great for about half an hour, then starts runnin like crap.
I think I remember that van... guy (Phil) had a build page on CarDomain... great condition! If it's the one, it's a gooder!!! Welcome!!!
In a pinch, you could make like a shroud out of sheet metal that would serve to deflect air rising off the manifold around the carb... cut out for the bolt holes and intake and sandwich it between the carb and intake... just tossin that out there, not from experience.
welcome to the site! i fabricated a 3/8" micarta or phenolic spacer for my carb. i also rerouted and insulated the gas line because the fuel was getting too hot. you can probably get some scrap micarta at a place that repairs aircraft. thats how i got mine.
sasktrini wrote:I think I remember that van... guy (Phil) had a build page on CarDomain... great condition! If it's the one, it's a gooder!!! Welcome!!!
i think i'll try making that item out of titanium at the hanger, it is refractive and should be just right for this role... good idea. if it works i'll make a template so more can be produced
I have access to a full machine shop, and yeah, I think I will try to get ahold of some phenolic material and just make one. I gotta wrap the fuel line too as mentioned. Its the van off the cardomain site, I saw it on there, then I saw it for sale, and jumped on it quick! Phil, the guy I bought it from, was a heck of a nice guy. I had an A-100 in the past and I also have a '71 westy. Oh, if somebody beats me to making one I might be interested in purchasing (the spacer) I dont get down to the shop enough.
ok, hopefully I just found the proper phenolic spacer and some heat wrap tape for my fuel line and we will see if that works! Sucks trying to drive your van when it starts lurching due to carb boil. Some more about the van since this is kinda my intro: 66 Falcon, I got both original front seats, both original rears, all the falcon trim for the exterior, the side step is there and works. He built it with a stout C-4 so I can plop a V-8 in there if I ever feel the need, but it hauls ass with the 240. I will probably throw some disks on the front, and make a cold air intake similar to the one seen on "the modern form" website. Seems like these vans would really like some cold air to suck on? Oh yeah, 9" rear also. I bought the van to cruise around for the summer, and I can also haul my panhead chop in the back if needed.
Cool story! I thought it was the one!
Might not simply be carb boil... could be contamination in the fuel. Even if Phil rebuilt or replaced the carb, an old fuel tank may send crud that will gum the float needle up pretty quick. My Holley 1B is really bad for that. So if you don't have an inline fuel filter immediately before the carb, you might want to consider one. With mine, it would flood and I'd have to tap the side of the carb to loosen the needle. But you could see fuel squirt out the top like it was boiling.
But if you don't have a cooling spacer installed, well yeah, should have one.
Cheers
Cheers
