    A-100 nose protector
    kermit
    Number of posts : 41
    Registration date : 2008-05-27
    A-100 nose protector Empty A-100 nose protector
    Post by kermit Thu Aug 14, 2008 12:07 pm
    I'm trying to find out if there's a source for either a used (unless someone still makes new ones) bug protector for the front end, or some pattern, suggestions or instructions available somewhere to make my own.
    Kermit
    A-100 nose protector Empty Re: A-100 nose protector
    Post by Guest Fri Jan 25, 2013 8:44 am
    A tarp,a blade to cut out the headlight holes and bungee cords.Be sure to wrap the metal ends of the cords with ripped up rags,so ya don't scratch your PAINT...
    Post by Guest Fri Jan 25, 2013 8:57 am
    Maybe my sarcasm'l get me killed one day..who knows,.....I'm not sure they even make em' .....hell man you asked that question years back,you still around? Whats been goin on? still got your van? if so,what kind of problems have you run into/solved?
    Number of posts : 3046
    Post by RodStRace Fri Jan 25, 2013 1:26 pm
    As van go said, the pattern is right there in front of you!
    I'd check out the local pro upholstery shop. They should be able to whip one up for you. Just make sure that it's nice and soft wherever it touches and it's tight when installed so it doesn't flap and wear your paint.
      Current date/time is Mon Nov 25, 2024 12:34 pm
