    engine cradel
    Number of posts : 922
    engine cradel Empty engine cradel
    Post by wylee Mon Apr 12, 2010 2:00 pm
    just starting...engine cradel 100_0630engine cradel 100_0631
    Number of posts : 1319
    engine cradel Empty Re: engine cradel
    Post by 67a 100 pickup Wed Apr 14, 2010 8:24 am
    Looks like you don't trust the engine stand?? I have one like that from tractor supply.
    Post by wylee Thu Apr 15, 2010 3:31 am
    im making it so i can run the engine on it.to get the bugs out before i put in .
    Number of posts : 3046
    Post by RodStRace Thu Apr 15, 2010 6:37 am
    A few things I see that are constructive criticism....
    Mopar starters bolt to the bellhousing area. Unless you set it up with a flywheel and man trans bellhousing or a flexplate, torque converter and A/T, you won't be able to start it.
    That's a lot of weight pretty high in the air, add the torque reaction when you rev it and it's an accident waiting to happen. Have the motor lower or the base wider.
    You will want a cooling system (radiator, belts and fan) for any length of running time. Making it to be easily removable is a good thing. You also want a control panel with oil pressure and coolant temp gauges. Having the ignition and start switches there too makes it handy.
    Leaving room for some exhaust system is a good idea.
    You also want to consider a gas tank and a battery in the design.
    Fancy ones break down or fold up to take up less space.
    Some examples:
    http://taylorspecialties.com/enginestands.html
    http://www.fordmuscle.com/forums/engine-articles/471021-homemade-engine-run-stand.html
    http://www.easy-run.net/c-2-products.aspx
    http://hotstands.com/gallery.html
    I've fired up a 460 V8 sitting on the floor with nothing more than a battery, jumper cables and a 2 gallon gas tank and hose. It was fun to watch the flames out of the manifolds, and have it dance across the floor when you reved it, but if you are going to spend the time to build a stand, you can do better!
    Post by wylee Fri Apr 16, 2010 4:00 am
    thanks for the coments. thats the way im going.
    Number of posts : 655
    Post by 61econoline Fri Apr 16, 2010 8:13 am
    working on one myself.engine cradel Gedc0711engine cradel Gedc0712
    Post by wylee Sat Apr 17, 2010 3:43 am
    i like your gauge panel.............
    Post by 61econoline Sat Apr 17, 2010 7:57 am
    yea old chairs can be recycled too Very Happy
    Post by wylee Sun Apr 18, 2010 1:57 pm
    a little closer......engine cradel 100_0633engine cradel 100_0634
      Current date/time is Tue Nov 26, 2024 4:21 am
