    engine 1977 250
    thomas r traver
    Number of posts : 3
    Registration date : 2010-02-25
    engine 1977  250 Empty engine 1977 250
    Post by thomas r traver Wed Mar 17, 2010 11:07 am
    61 econo c-4 tranny will a 1977 250 motor bolt right up if not why
    Last edited by thomas r traver on Wed Mar 17, 2010 1:18 pm; edited 1 time in total (Reason for editing : why not)
    engine 1977  250 Empty Re: engine 1977 250
    Post by Guest Wed Mar 17, 2010 12:36 pm
    no.
    Number of posts : 2198
    Post by EconoUSAparts Wed Mar 17, 2010 5:11 pm
    Because theres no such thing. Econo C4's werent even produced until 1964.
    Number of posts : 12246
    Post by donivan65 Wed Mar 17, 2010 6:01 pm
    So do you have a 61,,,, or a C4 or hoping to get one or a 250?
    thomas r traver
    Number of posts : 3
    engine 1977  250 Empty moter
    Post by thomas r traver Wed Mar 17, 2010 6:18 pm
    donivan65 wrote:So do you have a 61,,,, or a C4 or hoping to get one or a 250?
    [i have a 61 with automatic i thought the tranny was a c4 will look i found a 250 runs for 100.00 wanted to know if swap is possible without much problems this van has 144 motor the dealer put a automatic in for a handycap person called trans shop says its a fmx trans its 32 an half inch long drive shaft is 19 an a quarter long thanks for your help
    Last edited by thomas r traver on Thu Mar 18, 2010 10:36 am; edited 1 time in total (Reason for editing : new info)
    Post by donivan65 Wed Mar 17, 2010 6:57 pm
    Sometimes people change things, so you need to find out which engine and trans you got and then you can find out what you can change. So Guys, if he wants that 250, then what are his choices for a transmission that will fit in his van?
    Post by EconoUSAparts Wed Mar 17, 2010 7:51 pm
    If theres a trans. crossmember its not original. If it hangs off the stock mount its out of a 64 or at least a 64 tailshaft. Im not familiar with the 250 but I think Fred is.
    Post by Guest Wed Mar 17, 2010 7:55 pm
    The Econo tranny has a short tail housing on it. I am not sure but I think the motor should bolt on but there are still other mods you would have to do.
    fmc56
    fmc56
    Number of posts : 553
    Post by fmc56 Thu Mar 18, 2010 3:01 pm
    If the transmission is bolted to a 144/170 or 200 it will not bolt to a 250. The 250 uses the same bell housing as a 240/300/289/302. The 250 will not bolt to the motor mounts either.
    Fred
    Post by donivan65 Thu Mar 18, 2010 5:46 pm
    So by making up a engine/trans mount and a driveshaft, what choices would he have for the 144 family of engines,,,,,,and how about the 240 family?
    fmc56
    fmc56
    Post by fmc56 Fri Mar 19, 2010 5:42 pm
    To Install the 250 in a 61 is a lot of work. The engine is taller, wider and uses a larger bell housing. All of these cause problems. Since the engine is wider it won't fit on the original cantilever arm mounts, you could shorten them but the added power and weight of the 250 puts them at their limit. I have done it with no problems but using a tubular crossmember from a 65-67 would be the best choice. You'll have to fabricate some mounts to attach it to the frame and modify the engine mount towers to fit the 250 to it. Second problem is the height of the motor. It will fit in the 61-64 motor box but the carb will hit the cover. You'll have to swap over to a taller 65-67 box. Third problem is the larger bell housing, it wil hit the floor at the rear of the motor box. You'll have to put the floor hump in also. Next is the transmission mount, good luck finding a 64 auto tailshaft, at least for a resonable price. Better to use the 65-67 style and buy an adapter from Blue Oval. You'll also have to upgrade to a 9" rear axle and you'll need the large u-joint driveshaft. For the amount of work involved it's simpler to just bolt a 200 in. After all that is said I am putting a 250 automatic in my 63 pickup. I have all the parts though.
    Fred
      Current date/time is Fri Nov 22, 2024 8:32 pm
