I hope to begin work on my interior soon and plan to use black auto carpet (the short fuzzy kind, not loop pile) on some areas. The carpet will be covering plywood.
My plan is to use spray glue and attach it to the plywood. My concern is that I need to get a very flat fit - no bubbles. I've not done this before, and was thinking it wouldn't be too much of a problem, provided I was careful to "work" the carpet onto the wood. This would include using a flat surface "tool" like a piece of wood, carpenter level, etc. Spraying both sides first and letting the glue set up for a couple of minutes wil probably be necessary.
I really wasn't worried about this until my wife watched something on HGTV about attaching fabric to a window shade, and although I did it for her very carefully (using methods similar to above) the results were less than I had hoped for. There were bubbles, not bad ones, but definitely not what I was shooting for, and would be unacceptable to what I want to do with the Van. Perhaps the carpet will be easier to work with than this fabric was, but the fabric was kind of stiff, and hence my concern that the carpet could have the same issues, or worse.
Any hints - cautions?
