The needle only pegs in one position - way above full. It never pegs anywhere else. Except of course when the ignition is off, which it's supposed to do.
Update to the update: the gauge pegged way above full again. I discovered that the connector by the taillight didn't fix the problem. I finally gave the wire going from the taillight area to the fuel sending unit a few gently tugs under the chassis, and that fixed the problem again.
So I guess once the weather turns dry (sometime around June) I'll be pulling the tank again and inspecting the sending unit. It may just need a little solder or crimping or something.
