I'm trying to figure out if my fuel gauge is bad or if the sending unit is the culprit.
Anybody have any suggestions?
Most likely! There is a wire connector (should be tan? 2nd gen color diagram?)coming from the floor below the left side tail light, look there and clean it and ground as Doni said with a test lead and turn the key on and off. If its the sender, Doni has a great repair for it, he's posted it many times....you cannot buy one new...K-Noods68 wrote:OK, so if I disconnect the wire and the needle doesn't move, then my problem is the gauge?
And, if the gauge does move, then the issue is the sending unit?
