I need to find sheet metal screws similar to the ones here. This one I happened to find in a can of odds and ends, and isn't exactly what I need, but would do (needs to be longer though). 30 years ago I could walk into a van customizing shop and buy a box of 100 screws that had the recessed washer already attached. This one is flat, but hopefully you might know what I'm referring to. I would prefer them to be anodized black, but I could paint them if need be. I've been to Home Depot and two Mom and Pop hardware stores, but so far no luck. I know they can't be that hard to find. Any suggestions?
+5
back2thewoods
mo_1040
southern man
9 posters
Need source for trim screws
Re: Need source for trim screws
Is there any bodyshop supply stores around??? I know the the bodyshop supply store in my town has every kind of trim screw you can think of...
You might try Steelies or Restoration Specialists for those screws. They both have an good choice.
back2thewoods- Number of posts : 842
i use a place called the nutty company, in ct. dont know if its a chain, every nut , bolt, screw imaginable, found ones for door panels there in stainless
You can get them in small quantities in Auto Zone or other autoparts chains, they are called Trim Screws I think. They come in black and chrome. I also seem to remember that you can get them in bulk from JC Whitney
wideload- Moderator 1st Class
- Number of posts : 1388
If there's a Fastenal store near you they might have or could get them.
Mike
WIDELOAD
I think I can get those at my local hareware store????
Vanish- Admin
- Number of posts : 5155
Don Those are simpson strong tie http://www.strongtie.com/products/quikdrive/fasteners/steeltosteel.html#trsd Witch are at Home depot .... Those are Great !!!!!!!!!!
,,,Vanish,,,
MCMLXV
"I also seem to remember that you can get them in bulk from JC Whitney"
They have something similar (and trim screws is the correct term I guess) but it seems that they only offer them in mixed bag orders - where you get a sampling of all kinds of screws.
I'll have to check out all the auto parts stores. Those self tapping screws that Don posted are handy little devils, and although I hadn't seen the kind he pictures they would certainly work for my needs.
Thanks guys!
Thanks guys!
jkr- Number of posts : 1148
a perfect match for them is holding the dash panels in every dodge on the road. go to any pic a part with a #2 phillips and start removing them. whenever i go into the local yard i get as many as possible.
