    Dash knobs for a 64.
    LiveWire64
    LiveWire64
    Number of posts : 244
    Registration date : 2009-03-17
    Dash knobs for a 64. Empty Dash knobs for a 64.
    Post by LiveWire64 Sun Dec 27, 2009 10:17 am
    My 64 van is missing all the dash knobs, lights,wipers,heater,etc. What do the correct knobs look like & can I get new ones? Does any other model of GM vehicle use the same style of knobs?
    Is the turn signal switch assembly available?
    Also, how many switches should be on my steering column support? I have two. One is the heater & the other is hazards. Is this correct for my 64? Thanks,Brad
    Dash knobs for a 64. Empty Re: Dash knobs for a 64.
    Post by donivan65 Sun Dec 27, 2009 11:09 am
    If you got that big ugly hazard switch with the red light on top, then it is the real one,,,,,however, all the real ones I seen were like hidden under the dash to the right of the fuse box. But I see a lot of switches and gauges added to that steering column support,,,,I have 4 switches on mine,,,,,And the turn signal switch is Delco D6202,,,same as corvette,,,,they are about $100,,,,,but the hard part is getting the cancelling cam that bolts under the steering wheel. WideLoad put a pick up switch in his van,,,,,,,,,
    Post by donivan65 Sun Dec 27, 2009 11:36 am
    And it is a Corvair dash,,,,,the speedo reads 100 mph instead of the 85 on the Corvair,,,,,this is a 64 Chevy Van,,,,,,
    Dash knobs for a 64. Nodoor10
    Dash knobs for a 64. Nodoor11
    LiveWire64
    LiveWire64
    Post by LiveWire64 Sat Jan 02, 2010 4:31 pm
    Ok, after looking at what I have, I know the heater switch was the only factory switch on my steering column support. The added on switch looks to be a ford switch. It was used as the emergency flasher switch.
    Don, are the stock knobs available anywhere? Did any other make or model of GM vehicle have them?
    As for my 80mph speedo, I have been told the early 1st gens did have them.
    Thanks for any help,Brad
    Post by donivan65 Sat Jan 02, 2010 6:07 pm
    I have never seen a 80 MPH speedo in a van,,,,,even the 64 here has a 100 MPH one,,,,so,,,,maybe they stole yours out of a corvair or they put those 80's in the 4 cylinder models so you wouldn't feel so bad,,,,,,,(like that would work),,,,,so lets see if anybody else has something different then the 100MPH speedo in their 1st Gen,,,,and how many knobs do you want,,,,,they all seem to look something like this,,,,,cone shaped,,,,,and the heater knobs never match,,,,,my hot rod buddies buy knobs for their 64 malibu and 68 camaros from the hot rod stores online,,,,,sure look like they also fit vans,,,,,,
    Dash knobs for a 64. Repair21
    Post by Vanish Sat Jan 02, 2010 6:14 pm
    I Have heard that some of the Canadian Vans came with the 80 mph Speedos ?????????
    Post by donivan65 Sat Jan 02, 2010 9:52 pm
    ,,,,,,,,like in 80 KPH???????
    Post by Vanish Sat Jan 02, 2010 9:54 pm
    They werent metric in 64 ........
    Post by donivan65 Sat Jan 02, 2010 10:00 pm
    ,,,,,,,,so Brad could have a Vauxhall or Acadia van??????
    LiveWire64
    LiveWire64
    Post by LiveWire64 Sat Jan 02, 2010 10:36 pm
    Thanks Don. I will look around online & see if I can locate some knobs for a malibu. I really like the look of the stock stuff,otherwise I would just make some out of wood.
    Never seen any Canadian vans,but I know by my VIN that my van was built in Pontiac,Michigan. Here's a link to the thread I posted on VCVC. That's where I 1st heard about the 80 & 100 MPH speedos. Take care & thanks again! Brad
    http://www.vcvc.org/ubb/Forum1/HTML/005245.html
    Post by donivan65 Sat Jan 02, 2010 11:07 pm
    Maybe they were just trying to use up the last of the Corvair Speedos or someone put a Corvair in there,,,,,,the new vehicle training book says the speedos are 100MPH,,,,,,
    Dash knobs for a 64. 80_spe10
    Post by donivan65 Sat Jan 02, 2010 11:23 pm
    The headlight switch knob is part of the shaft,,,,,and you need to see what type of knobs you need,,,,,,serrated or D shaped shafts,,,,and probably all GM vehicles use the same knob shafts,,,,,(sounds like a Pick a Part adventure),,,,,,and check the Corvair websites,,,,,they probably have at least some of those knobs for sale
    Dash knobs for a 64. Repair23
    Post by donivan65 Sat Jan 02, 2010 11:26 pm
    Post by donivan65 Sat Jan 02, 2010 11:36 pm
    Number of posts : 2626
    Post by savage Mon Jan 04, 2010 6:28 pm
    The Corvair headlight knob shaft is just a little longer then the one on the van(found out hard way )Might just be the early ones?? If you don't want mint ,I got some
    Post by donivan65 Mon Jan 04, 2010 10:57 pm
    Tom, the Chevy headlight shaft is 2 3/4" long,,,,how long do you think the Corvair was?
    Dash knobs for a 64. Img_1010
    LiveWire64
    LiveWire64
    Post by LiveWire64 Sat Jan 09, 2010 12:31 pm
    Hey Don,
    There is a Corvair headlight knob on Ebay right now. Says the shaft is 3 1/4" long. Learn something new every day. Good stuff to know though. Brad
    Post by donivan65 Sat Jan 09, 2010 6:46 pm
    I guess you would be forever trying to push that knob in all the way to turn off the lights if you put a Corvair one in there.......
      Current date/time is Thu May 02, 2024 4:53 am
