by sasktrini Thu Dec 24, 2009 10:41 am
Did a little painting last night, as the tenant downstairs was gone back to the farm for Christmas... no one to offend with paint fumes in the house!
Off the 65 SuperVan is the disassembled heater box and the new wiper bracket. Off the 63 panel is the tranny linkage, gas tank straps, parking brake w/ antique stove handle, clutch rod and pedal. All have been stripped, degreased, etch primed and surface primed with black. All that's left is the gloss black topcoat. I might hit that today, as I'll be spending the next few days over Christmas at my gf's and the family. Fumes won't bother me any either!
All these pieces used almost a full can of etch primer (except the plastic heater box), and a full can of the flat black primer. And I didn't get frostbite either! After Christmas, I should be back into reassembly of some of these components, and hanging them up to wait their turn for reinstallation!
I actually have my tranny in the house too, waiting for detailing! I think I want to go with Duplicolor Cast Iron Engine enamel for that, to match the engine block. Engine block needs touching up too, but I don't think I'll bring it into the house.
Question: use the same primers under a high-heat paint like engine, caliper or manifold paint? My unprimed valve cover, oil pan and block have flaked off paint in places. It's the one in front, you can see the flaking more on the oilpan, but paint adhesion is a problem all over.
Thanks!
After a google search, I see the answer is "no", as the primer isn't designed to handle the high temperatures. Either I had grease on the surface, or I didn't scuff the surface (probably... drill-mounted nylon brushes seem to polish clean metal). So while I have the engine sitting in the cradle, and the tranny out, I'll try to make sure it's got a little bite for the engine paint to hold on to! Oh, and I did hit my parts with Duplicolor Truck and Van Universal Gloss Black. Soon, I'll reassemble my park brake lever and heater box!Last edited by sasktrini on Thu Dec 24, 2009 3:26 pm; edited 1 time in total (Reason for editing : engine block painting answer)
