    300 CID INSTALL
    Dan Scully
    Dan Scully
    Number of posts : 254
    300 CID INSTALL  Empty 300 CID INSTALL
    Post by Dan Scully Wed Feb 14, 2024 8:18 pm
    Helping a friend do this, what all is needed to install a 300 in place of a 200? Thanks
    Number of posts : 2086
    300 CID INSTALL  Empty Re: 300 CID INSTALL
    Post by Seth G Sun Feb 18, 2024 9:07 am
    A lot. From a practical perspective the van really needs to be a 65-67 to make it "easier". You'll need the 65-67 240 crossmember and transmission for the main parts. If you add a custom crossmember you could use a different tranny. Likely some differences in throttle linkage and so on. The van should have a 9" rear end if it doesn't already.
    If it was a 240 van it would be a direct swap.
    Dan Scully likes this post
      Current date/time is Wed May 08, 2024 6:36 pm
