    200 cylinder head or engine
    Fairlane514
    Fairlane514
    Number of posts : 36
    Registration date : 2023-01-28
    200 cylinder head or engine Empty 200 cylinder head or engine
    Post by Fairlane514 Wed Apr 19, 2023 9:56 am
    Looking for a 200 cylinder head or complete engine.
    Didnt see a classified section on the forum.
    200 cylinder head or engine Empty Re: 200 cylinder head or engine
    Post by donivan65 Wed Apr 19, 2023 10:21 am
    We do have a Parts Wanted section a little down lower....
    https://vintage-vans.forumotion.com/f15-e-parts-wanted
    Fairlane514
    Fairlane514
    Post by Fairlane514 Wed Apr 19, 2023 10:38 am
    Thank you, posted there
    chrlsful
    chrlsful
    Number of posts : 184
    Post by chrlsful Sun Apr 23, 2023 9:45 am
    you're a lill luckier than U think (it appears). Other heads fit/work.
    Many of us use
    https://www.vintageinlines.com/product-page/the-ford-falcon-six-cylinder-performance-handbook
    and
    https://fordsix.com/ci/Tech.html
    to go a lill further than U might have.
    Good Luck
    Fairlane514
    Fairlane514
    Post by Fairlane514 Sun Apr 23, 2023 4:24 pm
    Thanks a lot, really appreciate the link
    chrlsful
    chrlsful
    Post by chrlsful Mon Apr 24, 2023 4:11 am
    look at the references.
    U will see a 250 as a lill tq monster (well, not like the 240/300, I should have used the 300/4.9 efi in my bronk) the 200/250 heads often swapped as not much different, no + or - in performance - MPGs or HP/Tq) while the 200 a revie lill devil.
    LOTS of detail in those 2 sources (machining, ID-which U need, hop up, parts, a staged approach to ur ownership or build up & more) the latter - how to keep on rd while saving and moding toward ur needs.
    Or skip & reinvent the wheel (esp on LOM-SCV feed-back system).
    Good Luck, read then ask "the right Qs" if interested. We're here to help~
    Fairlane514
    Fairlane514
    Post by Fairlane514 Mon Apr 24, 2023 6:16 am
    Ok, thank you
    I was able to find two 200's. a 65 and 66 for 500.00 complete.
    chrlsful
    chrlsful
    Post by chrlsful Mon Apr 24, 2023 6:59 pm
    some times folks dont know what they are selling (have). Make sure YOU DO...
    Only 4 or 5 points to assure, know them (ID indicators).
    Fairlane514
    Fairlane514
    Post by Fairlane514 Mon Apr 24, 2023 7:18 pm
    They have 5 freeze plugs and 7 mains
    chrlsful
    chrlsful
    Post by chrlsful Tue Apr 25, 2023 9:56 am
    as U look @ the outside (I dont think it'll B apart) count H2O
    pump bolts, ck the pad up where the rd draft tube is/was for the 170 stamp
    too
    144/2.3; 170/2.8; 200/3.3; 250/4.1
    & the 2 bigger's w/removable intake
    240/300
    Fairlane514
    Fairlane514
    Post by Fairlane514 Tue Apr 25, 2023 12:15 pm
    I was able to remove the oil pans on both........7 mains and 5 freeze plugs
    chrlsful
    chrlsful
    Post by chrlsful Wed Apr 26, 2023 6:28 am
    dont need em open (much),
    learn castings ID (its easy
    heads seperate from 'log')
    more than "frz plugs'n mains":
    https://fordsix.com/ams/small-six-identification.1/
    Fairlane514
    Fairlane514
    Post by Fairlane514 Wed Apr 26, 2023 6:38 am
    Ok, thank you
    I checked the casting numbers, integrated intake,....... they are 200's
    chrlsful
    chrlsful
    Post by chrlsful Thu Apr 27, 2023 4:31 am
    casting numbers show ~ age, a good thing to no, not model (itsa ford, not cheb).
    For exact ⊝ born date ⊝ look between the castings that look like the
    red here (2 cast-in screw heads). I'm not sure how to do so myself, can "geta guy". After 50 yrs
    heads'n block can B swapped, of course, Y I recommend a check.
    Have fun, B safe AND productive !
      Current date/time is Wed May 01, 2024 11:02 pm
