    ford 240/300 cylinder head question
    ford 240/300 cylinder head question Empty ford 240/300 cylinder head question
    Post by Guest Wed Nov 30, 2011 1:08 pm
    hi, i'm getting ready to rebuild a 67-68 240 motor i for my econoline and the core i have has the holes in the head for air pump set-up. obviously i don't want to run the air pump but the head still has the holes in it.
    my question is should i plug the holes or find a another head? has anyone had luck plugging up the heads on one of these... and if so what type of plugs did you use?
    if i should replace the head i think finding a 240 head may be tougher than finding a 300 head. can i use a 300 head in place of the 240 without making any modifications?
    any help or advice would be appreciated. thanks
    ford 240/300 cylinder head question Empty Re: ford 240/300 cylinder head question
    Post by Guest Sun Dec 04, 2011 4:43 pm
    The guys here http://fordsix.com/forum/ will know for sure.
    Old Skool
    Number of posts : 1306
    Post by Old Skool Thu Dec 08, 2011 4:40 pm
    They make plugs for them, I have two 300 heads here with them installed. They were in the heads when I got them and not sure where to find them.
    vic
    Post by Twinpilot001 Thu Dec 08, 2011 4:46 pm
    earlier 302 heads have same problem as you are experiencing. The shop that rebuilds heads will have them in stock as will NAPA!!
    Number of posts : 2011
    Post by Barnabas Fri Dec 09, 2011 7:45 pm
    My 1968 289 had threaded holes for the air pump. They were standard pipe tread, so I got plugs from the hardware store.
    Check to see if your holes are internally threaded.
      Current date/time is Fri Apr 19, 2024 7:02 am
