    1967 park/reverse switch mount
    blacknblue67
    blacknblue67
    Number of posts : 2
    Registration date : 2021-10-22
    1967 park/reverse switch mount Empty 1967 park/reverse switch mount
    Post by blacknblue67 Fri Oct 22, 2021 1:28 pm
    Hi,
    I've been working on a 67 van with inline six and two speed powerglide. Had help changing the engine and now do not know how to mount the park/reverse swith. can someone post a photo please?
    Number of posts : 2626
    1967 park/reverse switch mount Empty Re: 1967 park/reverse switch mount
    Post by savage Fri Oct 22, 2021 1:57 pm
    Here a few . This is on a 68 G-20 with 307 & PG, but should be the same for 6
    "Not stock " Custom bent coat hanger linkage to switch.
    1967 park/reverse switch mount Img_0524
    1967 park/reverse switch mount Img_0525
    vanny and jrdunn96 like this post
    blacknblue67
    blacknblue67
    Number of posts : 2
    Post by blacknblue67 Sat Oct 23, 2021 8:51 am
    Wow, thanks. I'm so glad I joined this. Your photo is exactly what I needed. I can't thank you enough. Have a fantastic weekend.
    savage and jrdunn96 like this post
    AzDon
    AzDon
    Number of posts : 742
    Post by AzDon Fri Nov 05, 2021 8:03 pm
    What did that switch originally fit? Doesn't look original...
    Post by savage Sat Nov 06, 2021 7:36 am
    Don, It was on the van when I got it from Mark in CA, back in 07
    1967 park/reverse switch mount Img_0638
    Found others over the years, they look the same(mounting bracket, & lever ,have same 4 wire plug
    1967 park/reverse switch mount Img_0931
    AzDon
    AzDon
    Post by AzDon Mon Nov 29, 2021 8:32 pm
    Has anybody got a source for one of these switches?..... I can't find one... Actually rigged up a toggle switch to tell the ECM if it's in gear.... this would be way better
      Current date/time is Sun Apr 28, 2024 1:15 am
