Have searched all over the forum for info on a replacement radiator. Because our trucks and vans are prone to running hot at times, I’m considering a three row radiator. Probably aluminum as well. Anyone have info on where to get such an animal?
Radiator replacement
docmcg- Number of posts : 205
Registration date : 2014-09-08
Keith D- Number of posts : 405
Re: Radiator replacement
Rather expensive!
Yep... Not cheap.
A few people on the forum have run them and reported that they are good quality and had good results keeping the engine cool.
Is that a bolt in fit(no modifications )???
Early Chevy vans we have to get 1 from Mustang & modify it
- Number of posts : 8731
i am running the fsr it's a universal so you have to drill your own holes . talk to champion as well the do have a rad that will fit as well. the problem with the a`s is the fad is narror and most stock ones are too wide...
hope this helps, I've used fsr around 10years now
OK... I have been looking at pictures of the most popular replacement aluminum radiators.
In the pictures the outlet on the bottom of the radiators is always on the passenger side. On my radiator it is on the drivers side. I assume that my radiator is stock ( but I'm not positive).
I have a 318 in my van, is the outlet for a V8 on the drivers side and a 6 cylinder on the passenger side or has a previous owner modified something?
69FW likes this post
On the drivers side.
my fsr rad is both sides with a supplied plug from the supplier
Thanks for the information... I also will be looking to upgrade my radiator soon.
