    Pertronix question
    Pdxgeo
    Pdxgeo
    Number of posts : 18
    Registration date : 2016-11-27
    Pertronix question Empty Pertronix question
    Post by Pdxgeo Sat Nov 28, 2020 4:15 pm
    I installed a pertronix unit on my dizzy today along with a flamethrower coil, new wires and plugs and now I have zero spark...
    Ive done this on other cars in the past and it was pretty plug and play, is there somrthing about this setup thats different?
    I have a 67 with 170 and I believe all parts are stock.
    Thanks
    Pdxgeo
    Pdxgeo
    Pertronix question Empty Re: Pertronix question
    Post by Pdxgeo Sat Nov 28, 2020 4:43 pm
    I am guessing its a loose wire or more likely a bad crimp. I will get back out there tomorrow when theres better light and figure this out!
    Number of posts : 690
    Post by jrdunn96 Sat Nov 28, 2020 5:21 pm
    You might also check the ground path. I've had that bite me before.
    JM2C,
    Jim
    Pdxgeo
    Pdxgeo
    Post by Pdxgeo Sun Nov 29, 2020 3:15 pm
    I have the wrong module, I have the 1261 and apparently a Load O matic dizzy so I need the 1266. I should have read the archive BEFORE starting the job...
    Order has been placed and I will update once done.
    Number of posts : 2086
    Post by Seth G Mon Nov 30, 2020 6:09 pm
    When I did mine I got a module that didn't align up to space it right with the acrylic spacer, I just elongate the hole. Like everyone said, make sure the ground is good and also you have to bypass the resister wire and run straight 12v to it iirc.
    Pdxgeo
    Pdxgeo
    Post by Pdxgeo Mon Dec 07, 2020 4:47 pm
    Update: I got the correct unit and installed it and it is like a completely different vehicle. It starts with a tap of the key now, no pumping, cranking or stalling! The rebuilt carb obviously has a lot to do with it as well but this is definitely the outcome I was hoping for!
    Otto likes this post
      Current date/time is Mon May 06, 2024 9:49 pm
