    NOS Door lock sets, what to look for 1968 1969 1970
    68vanman
    68vanman
    Number of posts : 124
    Registration date : 2012-09-29
    NOS Door lock sets, what to look for 1968 1969 1970 Empty NOS Door lock sets, what to look for 1968 1969 1970
    Post by 68vanman Fri May 22, 2020 12:46 pm
    This post is for reference information only, not a for sale ad. So I've been going thru my stash of NOS Mopar parts and I came across these two sets of key lock cylinders complete with keys. One is a 3 pack and the other is a 5 pack. As you can see in the pictures, these would work for the 1968 thru 1977 vans, not the 1967 or earlier year. I wanted to post the pictures so that you know what to look for if you happen to come across them via ebay or maybe a swap meet. From what I understand, lock cylinders work for 1964 thru 1967 models and then changed in 1968.
    NOS Door lock sets, what to look for 1968 1969 1970 Keys_310
    NOS Door lock sets, what to look for 1968 1969 1970 Key_cy10
    NOS Door lock sets, what to look for 1968 1969 1970 Keys_510
    NOS Door lock sets, what to look for 1968 1969 1970 Keys_511
    NOS Door lock sets, what to look for 1968 1969 1970 Keys_512
    NOS Door lock sets, what to look for 1968 1969 1970 Key_cy11
    NOS Door lock sets, what to look for 1968 1969 1970 Key_cy13
    NOS Door lock sets, what to look for 1968 1969 1970 Key_cy12
    NOS Door lock sets, what to look for 1968 1969 1970 Key_ta10
    NOS Door lock sets, what to look for 1968 1969 1970 Keys_311
    [url=https://servimg.com/view/19521625/274]
    [url=https://servimg.com/view/19521625/275]
    Number of posts : 1148
    NOS Door lock sets, what to look for 1968 1969 1970 Empty Re: NOS Door lock sets, what to look for 1968 1969 1970
    Post by jkr Sun May 24, 2020 12:31 pm
    now for ALL van owners regardless of the years. here is a quick tip. you notice the stainless metal cover that has 4 clips to the body of the lock cylinders. under that cover is a spring and usually a 2 part tumbler. if you have a spare lock and no key you can pop that cover off and remove all or some of the tumblers. the 2 part tumbler pins are what determines the key cut. but if all or some are removed the door will still lock and the vehicle will start. the downside any dodge key might open a door and start the vehicle. if you tell more than one person nobody will be the wiser. but to let you know the key can be removed at any spot in the turning radius so if you unlock the door and pull the key out without centering it a sharp eye can tell it's possible any key will unlock a door. remember there are only 5 tumbler depths and 5 locations in the key barrel. the combos are just that limited hence the newer keys having double cut keys. I have done many with one or two tumbler holes with nothing in them and some with just one. it's not rocket science. just don't mix up the tumbler pieces, the springs are thhe same. try it...
      Current date/time is Thu Jun 13, 2024 9:47 am
