My engine casting number research reveals my motor to be a Chev/Olds 64-76 230-250ci by casting number 3921968 . Without looking at the pistons, is there a way to find out if it is a 230 or 250ci? Also, if I want to do a direct swap with a new engine , does it matter for compatibility, If my existing motor is a 230ci can I just drop a 250ci without modifications? Thanks, EdD
250ci or 230ci
EdddieMello- Number of posts : 57
Registration date : 2019-08-28
250ci or 230ci
SteelyVan- Number of posts : 112
Re: 250ci or 230ci
There will be a set of numbers/letters stamped on the ledge of your block next to the distributer clamp. A 230 and a 250 (obviously) share the same block casting and are interchangeable in our vans. Make sure to keep all of your current motor mounting and linkage hardware for a swap. I have read where some have used a bendable wire (or similar method) to measure the length of stroke thru a spark plug hole. The 250 has a longer stroke.....3.75" vs 3.50"?? DOUBLE check me if you resort to this method.
Re: 250ci or 230ci
Thx Steely, I wrote down the numbers. I haven’t figured what all the rackett with my motor is but I think if I need to replace it, I don’t know why I wouldn’t go with a 250ci. I looked at a 350ci with a 2 speed auto a builder wanted to sell me but this van’s character is its being completely unmollested. Hopefully nothing serious though. edD
gfleduc- Number of posts : 367
Re: 250ci or 230ci
What year van do yo have?
If you get the casting date found near the dip stick boss & then the engine build code on the distributor mount pad I should be able to definitively give you the CI
Re: 250ci or 230ci
I don’t have access to the 1966 SportVan atm... but the casting # is: 3921968. I don’t have the build date. Is there any reason I can’t just swap, without any accessory changes, to a 250ci, even if what I have is a 230ci?
Eng Swap
Easiest and most common swap done!
Don't worry about the codes then...
Re: 250ci or 230ci
If its the original engive in your 1st gen, then its a 230. If you drop the pan, you can look at the crank casting number and that will tell you if its a 230 or a 250.
You can make a 230 into a 250 by changing crank and pistons.
