Hey everyone, I'm trying to collect the little bits to make my 64 complete. It's missing the Inner and Outer door handles for the back door. I looked inside, but I couldn't get my arm to reach to the bottom to find out if I need the backing plate, as well. As my shop was recently broken into and tools all stolen, I don't have my magnet anymore What I DO know, is that everything in the door still works; I was able to put a flat blade screwdriver into the square shaft and turn it so that the door still latched. I believe the lock still works, as well. Thanks everyone!
Looking for Rear Door Handle(Inner AND Outer) for my 64 G10
MicroMachinery- Number of posts : 14
Registration date : 2020-04-29
If you don't mind a OK outside handle I got a few, and the escutcheon , clip that hold in in. Right Back door don't have inside handle. At least not the panel vans. Not sure about Sportvan's ?? I put side door latch on back for my Nodoor ,so I have inside handle. I used a side door off a Sport so I also got inside lock.
PM me you adress
PM me you adress
Your right (passage side)back door has a inside handle??
That's a pic of my side door. The right rear door looks like it SHOULD
Thank you so much! I should work a treat! PM'd
Its on its way. Hope it helps
