    65 rear bumper and rear door handle
    Snarky
    Snarky
    Number of posts : 10
    Registration date : 2020-04-02
    65 rear bumper and rear door handle Empty 65 rear bumper and rear door handle
    Post by Snarky Tue Apr 07, 2020 4:36 pm
    Looking for both a" straight" rear bumper and rear door handle.
    PM me or call 4198899214
    Thanks
    Jim
    65 rear bumper and rear door handle Empty Re: 65 rear bumper and rear door handle
    Post by donivan65 Wed Apr 08, 2020 10:20 pm
    Passenger or Drivers side rear door handle?
    Snarky
    Snarky
    Post by Snarky Thu Apr 09, 2020 5:14 am
    Sorry, I meant the back door. It is the outside handle only. I broke it off. It appears to have two roll pins connecting the chrome handle to a square shaft inside. They appear to be connected with only about a #10 sized pin.
    Thank You!
    Number of posts : 2626
    Post by savage Thu Apr 09, 2020 5:56 am
    I got some, no where near mint ,but better than a broke one.
    Most outside handles (side & back doors)have a clip holding them into the escutcheon.
    Maybe Don will post some of his info pics to show in depth (inside of door0 of how it comes out
    Post by donivan65 Thu Apr 09, 2020 11:40 am
    ,,,,,,might as well talk about handles, since they are starting to hand out $1000 tickets if they catch you outside,,,,,
    So lets get started,,,,,the handle is held in by a clip, which usually breaks and falls down into the bottom of the door,,,,,do you think something is broken or just missing?
    65 rear bumper and rear door handle Dscn0912
    65 rear bumper and rear door handle Dscn0913
    65 rear bumper and rear door handle Dscn0914
    65 rear bumper and rear door handle Dscn0915
    65 rear bumper and rear door handle Dscn0916
    Snarky
    Snarky
    Post by Snarky Thu Apr 09, 2020 12:57 pm
    It is broked right in the the groove for the clip goes. It has roll pins on either side of the groove and a shaft in the center that looks to be about 3/16" in diameter. I have removed the roll pins and am considering welding it up an grinding a new groove back in place for the clip. This handle is otherwise in great shape.
    BTW: Good photos!
    Thank You!
    Post by donivan65 Thu Apr 09, 2020 1:40 pm
    Well,,,,,that shaft is 7/16" and the square is 5/16"....its all 1 piece,,,,so maybe someone tried to repair yours or tried to modify another type to fit,,,,,no way that shaft can break,,,,everything in the door will go before it,,,,does the door open if you stick a screwdriver in there showing that the lock and door rods inside are there and working?
    65 rear bumper and rear door handle Dscn0917
    Post by donivan65 Thu Apr 09, 2020 1:52 pm
    Post by donivan65 Thu Apr 09, 2020 4:36 pm
    Savage might have the answer,,,,,if you look at both the 1st and 2nd gen handle set ups, you see the 2nd gen has a stop and a wall inside the handle,,,,,now if someone tried to put the longer shaft 2nd Gen handle on a 1st Gen door, they would have to shorten the shaft,,,,,is that what you see?  so I dont have to keep typing,,,,someone tell us why are those 2 handles made different,,,,,,,,
    65 rear bumper and rear door handle Dscn0919
    Snarky
    Snarky
    Post by Snarky Thu Apr 09, 2020 5:27 pm
    It is the short one. The latch meninism works well. Someone must have repaired this one in the past.
    Thanks for your input!
    Snarky
    Snarky
    Post by Snarky Mon Apr 27, 2020 7:49 am
    Rewelded where it broke at the clip slot. I ignored the roll pins and welded, then reground in the slot. Works like a champ!
    Thanks All.
    Jim
    Post by savage Mon Apr 27, 2020 8:21 am
    Cool good to hear you got it fixed. Cool
    Post by savage Thu May 14, 2020 10:46 am
    Don, in the pic above you said that 2nd gens have the stop cast in them on handle and escutcheon?? ?(Right one in pic above) I'm trying to get one for member, and have more with ,than with out??
    Will it still work on a 64/?
    Thanks for All your Info.
      Current date/time is Sat Apr 27, 2024 11:22 pm
