driver's side window will not roll back up 1966 Handivan
Timcoke1
Timcoke1
Number of posts : 20
Registration date : 2014-12-06
Post by Timcoke1 on Sat Sep 09, 2017 10:27 am
I am unable to get the window to roll back up. I rolled it down below the top of the door and it will not go back up. The handle will not turn and i do not want to strip anything. I am currently trying to remove the wing window but now the glass from the main window has shifted forward and I am unable to take the wing window out, nor am I able to return it to it's proper position because of the glass sliding forward. Please offer suggestions. I have no idea how I can remove the regulator because of the tight space.
Timcoke1
Timcoke1
Re: driver's side window will not roll back up 1966 Handivan
Post by Timcoke1 on Sat Sep 09, 2017 11:48 am
Just got the whole regulator out... the mechanism won't turn back the one way... it could keep tightening but will not reverse... Does this mean that i need to replace the whole thing? and if so, any recommendations as to where to purchase?
Number of posts : 11684
Post by donivan65 on Sun Sep 10, 2017 1:57 pm
you can drill out the rivets in the handle shaft and pull that gear out,,,,,,,you need to clamp the arm down because the spring is pushing the window up causing the gears to jam,,,,,,pull the arm down and maybe the handle shaft can turn and you might see tooth damage or shaft damage,,,,
Timcoke1
Timcoke1
Post by Timcoke1 on Sun Sep 10, 2017 2:10 pm
if the worm gear is damaged, do i just get a re-manufactured assembly? the ones i see online have two additional wheels for the window to ride on... if it is just jammed and the drilling of the rivets works to free it up, then i just bolt it back together? did i turn it too far? i guess?
Post by donivan65 on Sun Sep 10, 2017 5:03 pm
that handle shaft kinda has bushings and a brake inside it,,,,,,try and unhook the spring to take the pressure off the gears and see if the regulator works,,,,,,,,, drivers regulators are usually worn out,,,,,
Timcoke1
Timcoke1
Post by Timcoke1 on Sun Sep 10, 2017 5:06 pm
if it is toast, do you have a good site to get a replacement?
I found this one, but don't know if this will actually fit...
https://www.parts123.com/parts123/yb.dll?parta~partsort~A2~cadefefx
Post by donivan65 on Sun Sep 10, 2017 5:19 pm
that 2 arm wont work,,,,,,try and get the pressure off the gears and see what you get and maybe see what it is causing it to hang up,,,,,
Post by donivan65 on Sun Sep 10, 2017 5:39 pm
kookykrispy
kookykrispy
Number of posts : 1474
Post by kookykrispy on Mon Sep 11, 2017 1:56 am
Macsdoghouse aka "Mac" Chris MacShane rebuilds them.  send it to him.  He built me one and it is like new.  Get a hold of him at the phone number in the links below:
http://macsautoglassal.com
https://www.yelp.com/biz/macs-auto-glass-robertsdale
Timcoke1
Timcoke1
Post by Timcoke1 on Mon Sep 11, 2017 12:03 pm
i didnt drill out the rivets yet... i did take the pressure off and it only allowed me to tighten it further.. but not back it off... I will reach out to "Mac" as well to see if he doesn't want me to before i were to send to him. (just in case)
    Current date/time is Fri Feb 22, 2019 3:02 pm
