+4
Wolfster
8 posters
    dash pad restore
    Number of posts : 1778
    dash pad restore Empty dash pad restore
    Post by m1dadio Sun Sep 03, 2017 7:08 am
    fifty year old dash pad
    dash pad restore 50_yea11
    remove brittle and loose vinyl
    dash pad restore Remove11
    cut out and slice off bad foam
    dash pad restore Cut_of11
    the right spray foam from local hardware store will be low expansion, stay spongy when set and act as a bonding structure. Of coarse the right beer is esential.
    dash pad restore The_ri11
    fill in the cracks rubbing the wet foam into the old foam with a spatula.
    dash pad restore 20170814
    dont try to do it in one go, too much foam makes for large gas bubbles.
    dash pad restore Fill_t11
    sand with coarse block paper and repeat as necessary to acquire correct shape..
    dash pad restore Block_11
    test fit prior to upholstering.
    dash pad restore 20170813
    dash pad restore Check_10
    wrap with thin high density foam sheet, then your new vinyl using a spray glue that dose not melt the foam.
    dash pad restore Cover_11
    dash pad restore Finish11
    install
    dash pad restore Instal10
    M1D
    savage, gmytych, vanny, Russell and Abee like this post
    Wolfster
    Wolfster
    Number of posts : 140
    Registration date : 2016-08-27
    dash pad restore Empty Re: dash pad restore
    Post by Wolfster Sun Sep 03, 2017 5:30 pm
    Nice job! Luckily the one on my Econoline wasn't as bad.
    Post by vanny Mon Sep 04, 2017 10:00 am
    M1, you must be the Most Interesting Man in the World! lol!
    Great instructional thread for those who haven't done this before...(like me!)
    This is a Fantastic site for all the information that can be gained in working on these vans.
    Your dash turned out Great!!! cheers
    gmytych likes this post
    Number of posts : 1651
    Post by Scott Fri Sep 15, 2017 3:21 pm
    Good stuff M1, but where do I buy a sheet of high density foam?
    Number of posts : 1383
    Post by BILLS66 Fri Sep 15, 2017 4:38 pm
    M1 You are very talented .Nice job ! Bill
    caleboh
    caleboh
    Number of posts : 48
    Registration date : 2017-12-25
    Post by caleboh Tue Jan 02, 2018 12:37 am
    Wow! You did a great job. Thanks for sharing.
    Stomper
    Stomper
    Number of posts : 53
    Registration date : 2013-01-18
    Post by Stomper Tue Sep 22, 2020 4:29 pm
    This is my next project. I haven't taken a close look yet at how it's installed. How do you get the dash pad off? Is it screwed in from underneath or does it pop off?
    Post by m1dadio Mon Sep 28, 2020 5:58 pm
    On the 2nd gen van there are Phillips screws across the underside of the lip and a series of nuts under the dash.;
    Stomper
    Stomper
    Post by Stomper Tue Sep 29, 2020 8:34 am
    Great, thanks!
    Stomper
    Stomper
    Post by Stomper Thu Oct 07, 2021 3:07 pm
    I'm (finally) about to start repairs on mine. The embedded bolts are not that long, and the nuts holding the pad down were pretty close to the end of the bolts when I took it off.
    Did you have any problems with the bolts not being long enough after adding another layer of upholstery?
    Mine seems rather brittle everywhere. Is there a risk of cracking the pad in unrepaired spots when re-installing, or is it more solid than it appears to be?
    Number of posts : 8729
    Post by dix Sat Oct 09, 2021 3:27 am
    great job
      Current date/time is Fri Apr 26, 2024 8:39 am
