I'm supposed to go look at a '64 Chevy van tomorrow and would like to know where to find the vin numbers...I did a search but didn't find what I needed...thanks
1964 Chevy VIN
dudley32- Number of posts : 68
Registration date : 2015-01-17
1964 Chevy VIN
Re: 1964 Chevy VIN
Right by your left shoulder as you are sitting in it. Also on a crossmember by the gas tank either behind it or in front. Usually hard to see if the tank is in.
Re: 1964 Chevy VIN
Yes, those two spots, a small silver metal riveted plate on the post by the shoulder and the frame number is stamped. You might be able to see the front frame with a flashlight if you can under it over the tank where the fuel line enters through the frame. The blue data plate down by the drivers door front post does not have the VIN, only GVW and engine details. I have a '64, if you get, ask away!
Here's the post vin, pic turned sideways...
