    Lazarusvan's 1964 Chevy G-10
    Number of posts : 1293
    Lazarusvan's 1964 Chevy G-10 Empty Lazarusvan's 1964 Chevy G-10
    Post by Lazarusvan Tue Nov 08, 2011 6:44 am
    Lazarusvan's 1964 Chevy G-10 Tes_va15
    Lazarusvan's 1964 Chevy G-10 Leak13
    Lazarusvan's 1964 Chevy G-10 Exhaus12
    Lazarusvan's 1964 Chevy G-10 Radiat12
    Lazarusvan's 1964 Chevy G-10 Tes_va14
    Lazarusvan's 1964 Chevy G-10 Van_412
    Lazarusvan's 1964 Chevy G-10 Differ11
    Lazarusvan's 1964 Chevy G-10 Van214
    Lazarusvan's 1964 Chevy G-10 Van612
    Lazarusvan's 1964 Chevy G-10 Van1511
    Number of posts : 648
    Lazarusvan's 1964 Chevy G-10 Empty Re: Lazarusvan's 1964 Chevy G-10
    Post by Rayallen Tue Nov 08, 2011 7:15 am
    sweet ride, looks to be in great condition all around.
    Post by EconoCarl Tue Nov 08, 2011 5:48 pm
    Lookin' good Lee!
    Post by Twinpilot001 Tue Nov 08, 2011 6:20 pm
    Hey Laz- i looked @ ur electric fan mount= just exactly like mine in my pickup. That destroyed my radiator due to looseness over time -just an experience -Happy Vannin
    Post by Vanish Wed Nov 09, 2011 6:38 am
    Lee I have never seen a heat shield Like that before .. Very cool !!!!! Great Looking Van ...
    Post by Lazarusvan Wed Nov 09, 2011 7:48 am
    Found some not so good interesting stuff when trying to make my passenger window and door work properly.
    This photo shows interior of door where rust appears to have been cut at some point.
    Lazarusvan's 1964 Chevy G-10 Door210
    Next photos show a more concerning issue in that interior door surface rust has fallen down and combined with the other surface rust and made a pile at the bottom. Photo is taken where the add on plastic vent cover is normally.
    It is now a wet "mush" that is a breeding ground for more rust. It is very wet and is certainly going to eat through the metal if it sits long enough. Second photo shows the pile at the bottom.
    Lazarusvan's 1964 Chevy G-10 Door410
    Lazarusvan's 1964 Chevy G-10 Door510
    Lazarusvan's 1964 Chevy G-10 Empty rusted doors inside
    Post by Twinpilot001 Wed Nov 09, 2011 9:25 am
    clean out the pile in bottom - there should be some small vent holes in botto of each door- usually on most near the seam of door skin?? yet look at bottom of door. Clean those out = and wash all inside the door to get all out & open & when dry vac to remove big pieces. you van also sand & use some primar or rust coating inside that area thats rusted. I do know from experiences - many manuf's in the 30-50's used a actual Tar coating inside doors & body panels for noise & rust protection- way before we had spray on chemicals to prevent.
    Post by Lazarusvan Wed Nov 23, 2011 9:07 pm
    Tires have great tread but noticed they have dry rot. Would you drive on this?
    Lazarusvan's 1964 Chevy G-10 Tire10
    Number of posts : 512
    Post by pan58head Thu Nov 24, 2011 6:17 am
    Once you get these doors dry buy some por and seal up that rust. Yeah its time for some tires
    kookykrispy
    kookykrispy
    Number of posts : 1533
    Post by kookykrispy Fri Nov 25, 2011 5:20 pm
    I think pretty much everybody's doors look at least that bad. Good for you for taking the time to fix it. This is a very common problem for these vans.
    Post by Lazarusvan Fri Nov 25, 2011 5:47 pm
    pan58head wrote:Once you get these doors dry buy some por and seal up that rust. Yeah its time for some tires
    Thanks, PH. Previous owner said they are fine, but I was really concerned when I started looking closely, particuarly because I've seen dry rot in the tread on other vehicles, but not on the side walls. Not really looking to drop at least $500 on tires this second..I'm getting really close to having to park this for a while.
      Current date/time is Tue May 07, 2024 11:05 am
