Front Signal Lights
The signal lights didn't work when I bought it. When I pulled the lenses the socket on the driver's side had too much rust to put in a bulb, and the passenger side had a bulb rusted into the socket.
This is how I fixed them..
Not much to look at here, just a shot before fixing the front signal lights.
Belly Pan removed, and nuts removed from the backs of the lights. Not much slack in the wires on the driver's side.
I cut the wires about an inch up the plastic wiring sleeve so I could slide the shrink tube over it later.
I used a screwdriver to slide into the sleeve and pop the insides of the socket out the front, making sure to pay attention to what color wire was on top in the bulb socket.
Steel wool wrapped around the end of a drill bit polished the the sockets like they were new again.
Using new socket innards bought from Auto Zone I marked the wire that belongs to the top contact in the bulb socket.
They were made by: Conduct-Tite!
Part Number: 85801
Barcode: 37495 85801
I slipped some shrink tubing onto the wires before soldering them in place.
Getting those nuts back on the back of the lights when remounting them wasn't very easy. It really helped to wrap my finger with tape, sticky side out. I could then stick the nut to my pointer finger, reach around the wires coming out of the back of the light, and get the nut started on the bolt.
Part Number: 85801
