    better cooling with an air scoop, lots of pics
    better cooling with an air scoop, lots of pics Empty better cooling with an air scoop, lots of pics
    Post by Guest Mon May 18, 2009 8:43 pm
    I had plans to convert my electric pusher fan to a puller and build a custom air intake scoop to move more air through the radiator in order to help cooling down my 300 better for the summer and a few minor drag races on our local strips.
    Thanks to my friend Caleb, we realized these plans this weekend with great results. Temps were always below 180, driving long stretches up hills on the highway, without fan ,at 70 mph. City traffic also didn't need the assistance of the fan in 75° weather.
    We build a bracket out of 3 inch long tubes and flat stock to move the rad forward and get the fan close to and behind it, without using the nylon rods, clearing the water pump pulley by 1/2 inch.
    We layed out angle iron stock around the box marks were usually the heater box sits on earlier models and up to the front of the dog house. Spot welded and drilled holes, cut the floor and doghouse and took the frame out for final welding. Bolted it back in using 18 1/4 bolts and nuts after cleaning the cuts and priming.
    Only trouble we had was to make another trans oil line to the rad, rebend the kickdown rod to clear around the rad, carve more space into the existing rad bracket to unbind the throttle cable and make another bracket out of flat stock to re-attach the accelerator linkage in place were we cut it out the floor.
    Cheers, Pat
    https://i.servimg.com/u/f61/13/21/46/94/extend10.jpgbetter cooling with an air scoop, lots of pics Extend10
    better cooling with an air scoop, lots of pics Angle_10
    better cooling with an air scoop, lots of pics Bracke10
    better cooling with an air scoop, lots of pics Floor_10
    better cooling with an air scoop, lots of pics Airsco12
    better cooling with an air scoop, lots of pics Air_sc10
    better cooling with an air scoop, lots of pics Airsco11
    better cooling with an air scoop, lots of pics Airsco10
    better cooling with an air scoop, lots of pics Air_sc12
    better cooling with an air scoop, lots of pics Air_sc13
    better cooling with an air scoop, lots of pics Empty Re: better cooling with an air scoop, lots of pics
    Post by Guest Tue May 19, 2009 6:03 pm
    Looks like it gets LOTS of air now.
    Number of posts : 655
    Post by 61econoline Tue May 19, 2009 7:10 pm
    great job thanks for the pics
    Number of posts : 987
    Post by RipVanArkie Tue May 19, 2009 7:32 pm
    Chevy Model:
    better cooling with an air scoop, lots of pics Dsc01110
    better cooling with an air scoop, lots of pics Dsc01111
    better cooling with an air scoop, lots of pics Dsc01210
    better cooling with an air scoop, lots of pics Pic00010
    Later,
    Rip
    2013 MidSouth Econoline Meet
    1967 Econoline Pickup
    1966 Econoline Supervan
    Post by RipVanArkie Tue May 19, 2009 7:33 pm
    Forgot to say, NICE JOB!!! Will you be building a console over it?
    Later,
    Rip
    Number of posts : 7900
    Post by DanTheVanMan Tue May 19, 2009 8:00 pm
    Great job Pat and Steve. I have always been a bit apprehensive about cutting a hole in my floor, but you guys make it look easy....
    Steve, any word on those pop-outs?
    better cooling with an air scoop, lots of pics Qr_cod10
    Post by Digz Tue May 19, 2009 8:12 pm
    Yeah that looks great. and will support the floor well.
    Post by Guest Wed May 20, 2009 3:19 pm
    Thanks,
    Yeah it supports the floor really well.
    Thought about a console to do a hidden radio install but I have to go in there one more time to make room for the offenhauser intake mani.
    Rip I guess we had the same idea Smile
    I think the easiest part was the floor cutting, I took the steering wheel off for better access.
      Current date/time is Fri Apr 26, 2024 1:02 pm
