    Dorman hinge pins same as NAPA?
    Dorman hinge pins same as NAPA? Empty Dorman hinge pins same as NAPA?
    Post by Guest Wed Oct 26, 2016 9:57 am
    The Chrysler hinge pins through NAPA have not been available for quite a while. "out of stock"
    does anyone know if the DORMAN 38404 is the same?
    Thanks
    Dorman hinge pins same as NAPA? Empty Re: Dorman hinge pins same as NAPA?
    Post by donivan65 Wed Oct 26, 2016 2:45 pm
    Here are the Napa dimensions,,,,,,and these are oversized for a new tight fit on our hinges,,,,,
    Dorman hinge pins same as NAPA? Dscn9241
    Post by Guest Wed Oct 26, 2016 3:02 pm
    Thanks Donivan
    Post by Digz Wed Oct 26, 2016 3:31 pm
    I've used both.
      Current date/time is Fri Apr 26, 2024 9:55 pm
