    69 G10 brake pedal rubber
    69 G10 brake pedal rubber Empty 69 G10 brake pedal rubber
    Post by Guest Thu Aug 25, 2016 1:46 pm
    Looking for brake pedal rubber. Can't find any that are listed for these vans but the 47-55 chevy pick up ones look right. will they fit?
    Number of posts : 940
    69 G10 brake pedal rubber Empty Re: 69 G10 brake pedal rubber
    Post by JackeFriend Thu Aug 25, 2016 4:03 pm
    Corvette or corvair will fit.
    kookykrispy
    kookykrispy
    Number of posts : 1533
    Post by kookykrispy Thu Aug 25, 2016 4:57 pm
    Pats 69 G10 wrote:Looking for brake pedal rubber. Can't find any that are listed for these vans but the 47-55 chevy pick up ones look right. will they fit?
    If this is what you are talking about, yes the reproduction pads for the 47-55 trucks fit, (and as Jackefriend points out, 1st gen corvair used the same pads),  but the re-pops are kind of tight on our vans, and don't always stay put on the pedal very well.
    http://www.ecklerstrucks.com/chevy-truck-clutch-or-brake-pedal-pad-1947-1955-1st-series.html
    A way I was able to help them stay on is apply grip-tape to the pedal itself, and then work the rubber pad over the pedal.
    Post by Vanish Thu Aug 25, 2016 5:23 pm
    Get Them From Steele The Rubber you get from Brothers Don't fit right and Will Crack in less than 6 Months !!!!!!
    http://www.steelerubber.com/search?year=1965&make=chevrolet&model=g10-panel&style=2-door-panel-van
    Post by Guest Thu Aug 25, 2016 5:31 pm
    Great! Thanks for the help!
    chiefcrewdog
    chiefcrewdog
    Number of posts : 27
    Registration date : 2017-11-29
    Post by chiefcrewdog Mon Aug 20, 2018 4:49 pm
    I know this is an old post but others might see it. www.dansclassic.com. Part Number: 55-2454 3 bucks each plus the mail. fit perfect.
      Current date/time is Wed May 08, 2024 12:13 am
