    Straight six fuel pressure
    No1rascal
    No1rascal
    Number of posts : 306
    Registration date : 2013-02-19
    Straight six fuel pressure Empty Straight six fuel pressure
    Post by No1rascal Sun Aug 21, 2016 9:11 pm
    Does anyone know what the stock fuel pressure is on a straight six? Recently acquired a 65 that a PO had installed an electric pump. It has a fuel pressure gauge installed that shows between 9-10 lbs, that seems high to me.
    Any info is appreciated.
    Thanks
    Straight six fuel pressure Empty Re: Straight six fuel pressure
    Post by donivan65 Sun Aug 21, 2016 10:06 pm
    3 to 4 is normal,,,,,you need a regulator on that pump if you are going to use it,,,,,,
    Number of posts : 1412
    Post by Vantasia Mon Aug 22, 2016 5:42 am
    Yes, 2-4 lbs. and not continuous is all a six should have.  A good test of the stock mechanical pump is to pull the fuel line from the carb and insert it into a small plastic water bottle.  Crank the engine over and it should slowly fill the bottle in spurts in about 3-5 seconds, any faster its too high.  The stock pump is not continuous, only spurts a small amount of gas every time the cam comes around and pushes the lever like an old fashioned water pump.  You don't need a continuous stream like from an electric pump, you will only force fuel past the float valve.  Or as Doni said, use a regulator but a good one that goes low range is expensive, most start at 4 lbs.  Go with a new ethanol proof stock pump, sold everywhere, all you need.
    No1rascal
    No1rascal
    Post by No1rascal Mon Aug 22, 2016 5:47 am
    Thanks guys, thats what I thought.  PO had installed a new mechanical pump but never switched back to it, so I will just go back to that.
      Current date/time is Tue May 07, 2024 11:42 am
