What pressure for an electric fuel pump for my 144? Thanx Much!
Electric fuel pump pressure?
bratbike- Number of posts : 51
Registration date : 2011-08-29
Re: Electric fuel pump pressure?
7 max!! get it down to a low of 4.
Hawgford- Number of posts : 9
Registration date : 2015-08-17
I concur but why electric? Not against em got one on my V dub BeasTrike to switch to aux travel tank, but the old mechanical pumps are good stuff, came with a sediment glass bowl and less tax on the generator all things considered..
usually the mechanical pumps are somewhat $$ yet Id really only use them as then you dont have to remount & adjust fuel pressures & its way easier to install!!
Someone had changed my PU over to electric before I bought it & now it has gone out. Don't know what the pressure is so I thought that I axe the experts. So I should get a 4-lb pressure pump? Thanx Much!
most =INEXPENSIVE == elect pumps are not pressure adjustable!! Theyre set for the carbed engines. Install & forget. If you are looking @ one that is adjustable-likely its expensive one or you might need a pressure regulator. Now - That being said -id still get the oem mechanical pump & do away with the electric stuff!
Any recommendations on a mechanical pump brand? Do they just plug in the side of the block?
