by VANagain Sat Jun 25, 2016 11:42 pm
I wonder if the body shop did any prep on that surface when they painted my van. It looks like it's holding up pretty well.
I've been wanting to paint it black in there. Same with the area behind the main grill. My belief is those areas should just "disappear." Especially behind the main grill, which is now a mix of whatever it was before and turquoise overspray. That area is easy to get to from underneath but yeah, how to reach in to prep and paint behind the little one? Especially without messing up the nice paint on the grill! I had asked the painter about painting the black first but then how do you mask that off when painting the rest of the van?
I figure I'll tape over the grill with that low-tack blue tape. Then try wrapping a small piece of that 3M scuff pad over the end of a wooden tongue depressor. Should be able to slip that in and swipe it up and down to scuff it up. Then do the same thing with a piece of rag and that wax and grease remover.
Then, to paint it! I think if I used spray paint I'd end up getting overspray on the outer paint. Maybe use the rag on a tongue depressor method as a paint brush.
Yes, that big hole in the center is for the rubber grommet the windshield washer hose passes through. I assume that was just plugged on vans without the washer option. There's also a little hole on the left where the plastic retainer that holds the kick panel pokes through.
