by JackeFriend Sat Dec 29, 2018 2:49 pm
Started wrapping my exhaust manifolds on the van today. I finished the important side... mine, not sure how I might finish the passenger side, it is very tight next to the box on that side.
I can see how this is a task to be done when you are first installing the manifold... lol.
The difficulty I encountered feeding the titanium wrap through the 1/8" slit between the engine and the manifold was only matched by my inability to grab the wrap at the half way point from inside the cab, my arms are kinda short... like me
. So, I had to go under the van after each wrap until to the end. I felt like I was doing calisthenics! Up Down... Up Down whew!
But, I am stubborn and will not be defeated by unreasonably difficult tasks. Still need to cut the metal ties and tuck them. My cutters did not do it, I must be weak.
I hope the wrap helps in the overall temp inside the doghouse. Which in turn will make my area cooler when driving. I have heard it does help.
Since I have no real air conditioning...like some of you lucky guys. You know who you are!!
