    Horn, high or low?
    Number of posts : 2086
    Horn, high or low? Empty Horn, high or low?
    Post by Seth G Sun May 08, 2016 1:14 pm
    My poor horn sounds like a dying animal. Not sure what the tone of the oem horn is. High or low or did any come with both? I see there is an extra lead @ the horn for another.
    edit: I see now mine has "LO" cast into it so I guess it's a low.
    Also, iirc, it mounts behind the grill on the passenger side with the mouth facing the drivers side, is this correct?
    Number of posts : 690
    Horn, high or low? Empty Re: Horn, high or low?
    Post by jrdunn96 Sun May 08, 2016 1:53 pm
    Seth,
    Mine has both although I haven't heard them yet (A project in progress). They are also on the passenger side, opening facing the driver side.
    Jim in OK
    Post by Guest Sun May 08, 2016 3:59 pm
    For what it's worth, the horns in my a100 were toast when I got mine. Tried the heck top free them up to work. I installed horns out of a 63 Imperial as the old were dead. I wanted to keep it in the Mopar family.
    Post by Big W Mon May 09, 2016 9:02 pm
    I have both horns on my 66 and they seem to give off 2 different sound frequencies. High and low. Both point toward the driver side, and are slightly tipped downward. I will try to post a pick later this week if someone else hasn't posted one.
    Number of posts : 1466
    Post by uante Mon May 09, 2016 9:15 pm
    Here's a quick cell phone video that my girlfriend took of me driving by and honking. It's pretty sharp and loud and I didn't even lay on it, just tapped it.
    btw, the funny noise you hear in the back ground is Max the parrot putting in his two cents worth!
    Post by Seth G Tue May 10, 2016 8:06 am
    Big W a pic would be good, It doesn't look like two fit but alas they must. Thanks for the help guys. Brent your horn sounds great, Is it a single horn or two horns?
    Post by Twinpilot001 Tue May 10, 2016 8:15 am
    Grab a pair of stock horns off any lincoln!! affraid
    Number of posts : 2011
    Post by Barnabas Tue May 10, 2016 10:25 am
    Most Econolines I have seen came with one horn, either high or low, with the other connector taped over. I think the Falcons and possibly others had the dual horn option, which is both high and low horns. Having both makes for a loud and rich sound.
    Post by uante Tue May 10, 2016 11:38 am
    Mine is only a single horn with just one connector. I was surprised how loud it was when I got it working again.
    Post by Big W Tue May 10, 2016 6:58 pm
    This is a pic I took last year, and it's to close to really see them in full view....I will get another after the rain stops that shows more horn, and the dual brackets that hold them in there.Horn, high or low? Horns10
    Post by Seth G Tue May 10, 2016 8:39 pm
    Yeah, that's totally different from mine. My mounting bracket has 2 bolts where it mounts to the chassis and the horn is more ear shaped, not square, and the bracket meets it at 2 bolts in a C on it's body on 2 studs out of the horn. Neat stuff, thanks for the pic.
    neondv8
    neondv8
    Number of posts : 278
    Post by neondv8 Wed May 11, 2016 7:22 pm
    The sound of a high and low horns together has a great sound . But with all the rain we have here (you know what I'm talking about Seth)  it seems like once a year I have to take him out WD4 them and smack him with a mallet  to get them to work again.  Without the high and the low it sounds like a VW bus. HA HA
    BTW you can pick those up at the junkyard for only a couple of bucks
    Post by Big W Wed May 11, 2016 7:37 pm
    Yea the two horns together have a great sound. If I can get a video of them this weekend I will try to post it. I couldn't believe how loud they actually are. Impressive for 1966. How long will they last???? depends on how many idiots get in front of me...lol.
    Post by Barnabas Thu May 12, 2016 7:46 am
    Keeping the mud wasps out of the horns can be a chore. I am thinking of a screen over the opening.
    Post by Seth G Mon May 16, 2016 7:43 pm
    Mud wasps are a pain. More like hornets. I used to run into them in rooftop unit's, they can nest in the worst places. I've been fighting yellow jacket nests since I rolled the van outside.
    dv8, I think that's the culprit and maybe mud wasps to. There's some stuff rattlin round in there dry. I beat/shook alot out after getting the mud and water out prior Wink I'd love to rebuild it but they rivet'd those babies together real good
    neondv8
    neondv8
    Post by neondv8 Tue May 17, 2016 6:13 pm
    Seth G wrote:Mud wasps are a pain. More like hornets. I used to run into them in rooftop unit's, they can nest in the worst places. I've been fighting yellow jacket nests since I rolled the van outside.
    Spray it with BP blast , whack it with a mallet and hook it up to a cordless drill battery until the to diaphragms loosen up .
      Current date/time is Tue May 14, 2024 12:02 am
