    Horn relay
    Number of posts : 648
    Horn relay Empty Horn relay
    Post by Rayallen Mon Jul 02, 2012 7:02 am
    Question, can the horn replay be relocated. When I switched over to my alternator I tossed the voltage regulator seeing that I no longer needed it. In the process I removed the horn relay which is located below the voltage reg.
    I know there are others on here that have removed the Voltage Regulator but what did you do with the horn relay when you did? I finally hooked up my battery and everything electric is working besides the horn, thats how I figured out I removed it Embarassed
    Horn relay Empty Re: Horn relay
    Post by donivan65 Mon Jul 02, 2012 9:18 am
    You can put it anywhere,,,,you connect the horn, battery and the wire from the horn button to it and ground it to the body and you are good to go,,,,so if you put it under the dash, all you need to do is run a wire down to the horn,,,,the other 2 wires are close by,,,,,
    Post by Rayallen Mon Jul 02, 2012 10:12 am
    Sweet, thanks dude.
      Current date/time is Tue May 07, 2024 7:19 am
