by rustytoolss Mon Apr 18, 2016 9:23 am
jseiff wrote:I replaced the center section and the drive shaft, tightening the ten bolts in a 'star' pattern. I cannot remove the 5 nuts on the adapter plate (in front of the drum) because the axle does not have enough resistance from the drive. In other words the axle spins when I put pressure on the bolts with a ratchet.
Not a posi rear end.
Are you saying that you van has wheel adapters/ and you can not get those off, and have not even gotten off the brake drums yet ? If so you can not remove the center section until thewheel&tires are off/ drums are off/ axles out/ then center section.
If you do have wheel adapter, and the axle is turning while trying to remove them. Have someone push on the brake pedal, to stop the axle from turning.
P/S incase you do not know this early Chrysler vehicles had (LEFT HANDED THREADS on the WHEEL "STUDS"on the drives side of the vehicle) (Front and rear axles), Also there is the possibility that at some point in the vehicles life, that someone install a lefthand axle into the right side of the vehicle/ meaning you "could have 2 lefthand threaded rear axles, just athought.
You may be able to use a small hand help propane torch to heat up the nuts, to help loosen things up. Just be careful . Keep us posted.
