    brazing wing window pin
    jdlaugh
    jdlaugh
    Number of posts : 298
    brazing wing window pin Empty brazing wing window pin
    Post by jdlaugh Thu Mar 03, 2016 1:57 pm
    The driver side wing window pivot pin had broken on my '65 E-pup and great globs of caulk were the only thing holding the wing in place. I recently took the wing out of the truck and decided it would be possible to braze the pin back into place. I cleaned up the end of the pin and the plate it attached to and brazed the pin in place using a flux-coated brass rod.
    brazing wing window pin Wing_p10
    It looks like one small, inadequate tack weld was all that attached the pin to the plate in the wing frame. No wonder it came apart!
    brazing wing window pin Wing_p11
    After removing the glass and channel rubber from the wing, I cleaned up the end of the pin and the plate and tried to get everything properly aligned. Important note, the pin splines are indexed and the top washer has an "ear" that limits the travel of the wing. Make sure the indexed splines on the pin are pointed in the right direction. Guess when I figured that out... Embarassed
    brazing wing window pin Wing_p12
    This took longer to set up than to braze. A little cleanup and ready to go!
    brazing wing window pin Wing_f10
    Test fit. The brazed joint had no trouble handling the weight of the wing window held sideways. In the truck, there's really no stress on it, so this repair should be plenty strong.
    Now it's time to bite the bullet and buy the wing gaskets. $120?? affraid
    Number of posts : 2086
    brazing wing window pin Empty Re: brazing wing window pin
    Post by Seth G Fri Mar 04, 2016 1:09 pm
    Nice job. I would've worried about the heat doing something to the glass. Bravo
    jdlaugh
    jdlaugh
    Post by jdlaugh Fri Mar 04, 2016 1:30 pm
    jdlaugh wrote:After removing the glass and channel rubber from the wing,
    I took the glass and channel rubber out of the frame before applying heat. I don't know if the glass would have survived, but the rubber would certainly have raised a stink! Very Happy
    I took apart the passenger side vent, and turns out that pivot pin is also broken. Odd they were both broken. Maybe a bad run of parts from Ford in 1965. Or 50 years of abuse....
    Post by Seth G Fri Mar 04, 2016 11:02 pm
    oh duh, missed that.
      Current date/time is Sat Apr 27, 2024 12:53 am
