I'm swapping the I6 out for a 360 Magnum, got the frame brackets and engine mounts and rubber bushings from different people.
I already found out that the stud on the rubber mount on the frame side goes down, not up, and it fits it there fine now.
But I had to guess at attaching the motor mounts to the magnum block, and when the engine's in there, the rear of the block is close to the hump in the floor at the rear. I'm thinking the mounts need to be attached to the block in the rearmost position, as opposed to the fore-most position as I have it here.
Does this look right (passenger side mount) ?
http://www59.zippyshare.com/v/N1zmHFlU/file.html
Thanks
Thanks
