Does anyone know if a driveshaft from a 65 3 speed falcon van would work in a 61 3 speed Econoline truck? Any help would be greatly appreciated!
QCT
Drive shaft question..
QCT- Number of posts : 559
Registration date : 2015-01-01
Re: Drive shaft question..
id bet onit --yet old skl will know for sure!!
econopoor- Econoline Guru
- Number of posts : 1747
No. 61 and 62 had a slip joint on the rear of the trans. 63-67 trans had the slip joint in the center of the shaft and fixed yokes on the trans. There is a difference in lengths on 61-62 depending rather it has a 170 or 144. There are something like 13 different driveshafts for Econolines. All depending on what combo you have.
Duane.
Duane.
tody- Number of posts : 91
Registration date : 2010-09-15
here's a comprehensive list of all possible driveshafts:
http://econolineid.com/driveshafts.shtml?s=id
- Number of posts : 2011
If you have upgraded the transmission to the 1963-1967 transmission, then it might work.
See the transmission identification here.
http://econoline.org/transmission.php?s=id
Das Boot- Number of posts : 76
You guys really know how to crush some hopes and dreams. Got a 65 with a 3 speed and a peanut. Got a 9 inch from Tim and I was hoping I could use the same driveshaft. Doesn't look like that's going to happen. Crap, another couple of bills at the driveshaft shop. You know, it's getting harder and harder to hide the money getting put in the old truck from my wife.
That is a fairly easy fix, I think you are running the small six. Tim may can hook you up with the correct shaft. You can change the rear yoke to the little six trans and but thelarger yoke on it.
Duane
Duane
Das Boot wrote:You guys really know how to crush some hopes and dreams.
Reality Really Sux
