jdlaugh
Frostyvan
    Front nose replacement
    Frostyvan
    Frostyvan
    Number of posts : 3
    Registration date : 2015-11-08
    Front nose replacement Empty Front nose replacement
    Post by Frostyvan Sun Nov 08, 2015 7:14 pm
    Hey,
    I've been reading and learning lots over the past few days.
    I came across a thread that suggested replacing the front nose assembly?
    Did anyone ever end up doing this?
    I have a 69 that had a hit on the front drivers side back in the 70s.
    I'm sure that due to lack of panels they decided to pound it out and bondo.
    It's incredibly bad, grill seam is entirely filled in, signal lense is out of whack
    and the fitment on the drivers door is way off.
    I have a good shape front end off my parts van.  I'm going to have a resto guy look at it but he likely has zero experience with these vans. Is it really worth spending the time and money or is it better to find a better van to start with.  The rest of this van is in great shape.  It's been sitting since 83
    jdlaugh
    jdlaugh
    Number of posts : 298
    Front nose replacement Empty Re: Front nose replacement
    Post by jdlaugh Sun Nov 08, 2015 7:39 pm
    I repaired the driver's side nose of my Econoline pickup. I think it came out fine and wasn't as hard as I thought it might be. Details in This Thread
    bigdougalas
    bigdougalas
    Number of posts : 81
    Registration date : 2015-06-02
    Front nose replacement Empty front nose replacement
    Post by bigdougalas Mon Nov 09, 2015 10:21 am
    If your truck is as nice as you say SAVE at all cost
    Number of posts : 3046
    Post by RodStRace Wed Nov 11, 2015 8:04 pm
    Have a pro look at it and make the decision.
    Cut out and replace a section OR do the whole nose.
    Trying to remove and install it in factory sections rather than taking a sazall across the floor and butt welding (weaker) requires serious planning because of the way the nose is connected, especially at the front floor/frame rail area. It's complex and if this area is in good shape would require a LOT more work.
    Frostyvan
    Frostyvan
    Number of posts : 3
    Post by Frostyvan Wed Nov 11, 2015 9:35 pm
    I think you're right. After pulling the front dash/heater assembly, it looks much easier to just replace the nose on the factory seams. I think patching it in with the complexity of it may just be asking for trouble.
    There's a pro coming on Saturday to check it out. Thanks for the suggestions!
    Post by Big W Thu Nov 12, 2015 7:18 pm
    Welcome to VV Frostyvan.
    Number of posts : 798
    Registration date : 2014-10-14
    Post by GMman Fri Nov 13, 2015 5:45 am
    Replacing the nose section can be done but it is a little pricey. I had it done on my G10 van by a skilled body shop. Front nose replacement June_110Front nose replacement June_111Front nose replacement June_112Front nose replacement June_113Front nose replacement June_114Front nose replacement June_115Front nose replacement June_117Front nose replacement June_118Front nose replacement June_119
    Frostyvan
    Frostyvan
    Number of posts : 3
    Post by Frostyvan Sun Nov 15, 2015 9:05 pm
    Had the body guy out yesterday.
    He says to repair as is, can probably roll most of it out.
    I'm a little skeptical but, hes the pro.
    I'll post some pics of progress this week.
    Thanks for all your help!
    Post by GMman Sun Nov 15, 2015 11:40 pm
    It's hard to find a good body man that can tackle a nose skin replacement.
    Post by GMman Sun Nov 15, 2015 11:51 pm
    With the nose skin off the door hinge side could be pulled back into place. That's what was done with my van.
      Current date/time is Sat Apr 27, 2024 2:31 pm
